kkot 0 Posted September 6, 2017 Posted September 6, 2017 not working , ready to transfer ,but never downloads server-63640179491.txt 4d6c8ade-af7c-464a-8845-4d159279f283.log Capture.PNG S7 SM-G930V, android ver 7.0
0plus6 3 Posted September 8, 2017 Posted September 8, 2017 Same issue. Tried on Samsung Note 3 running 5.0, Samsung Tab E 8.0 running 6.0 and Samsung S8+ running 7.0. All have same issue. Media converts and then holds at "ready to transfer". Does this for every file type I throw at it. Server and Android apps all up to date.
revengineer 142 Posted September 8, 2017 Author Posted September 8, 2017 The Android app beta refreshed yesterday, but the issue remains. I see the same SyncJob error message as previously posted. Too bad, I thought I could download a movie for my flight home.
revengineer 142 Posted September 10, 2017 Author Posted September 10, 2017 Another beta has shown up and I thought I check again whether the pending movie has transferred. It has not and still shows as "Ready to transfer". I see the error message below, which appears to be related. I am not even sure whether these updates were supposed to address this issue. If you could let me know what the plans regarding this problem are going forward that would be much appreciated. Thank you! 2017-09-10 09:12:17.193 Info HttpServer: HTTP GET http://192.168.1.50:8096/emby/Sync/Jobs?TargetId=c1f796b6bac2f7e2. UserAgent: Mozilla/5.0 (Linux; Android 4.4.4; XT1095 Build/KXE21.187-42) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/33.0.0.0 Mobile Safari/537.36 2017-09-10 09:12:17.196 Info HttpServer: HTTP Response 200 to 192.168.1.70. Time: 3ms. http://192.168.1.50:8096/emby/Sync/Jobs?TargetId=c1f796b6bac2f7e2 2017-09-10 09:12:37.976 Error HttpServer: Error in SharpWebSocket: An exception has occurred while receiving a message.. Exception.Message: The header part of a frame cannot be read from the data source.
Luke 42243 Posted September 10, 2017 Posted September 10, 2017 Do you have google play services installed?
revengineer 142 Posted September 10, 2017 Author Posted September 10, 2017 I believe so. Doesn't that come with the OS and is required for the play store as well?
Luke 42243 Posted September 10, 2017 Posted September 10, 2017 Yea but if you're on a custom rom that might be having some kind of impact. I'm not sure.
revengineer 142 Posted September 10, 2017 Author Posted September 10, 2017 I am running stock ROM (see post #15).
revengineer 142 Posted September 10, 2017 Author Posted September 10, 2017 I should add, while I have always had trouble with syncing remotely, this used to work at least on my home network. But since I have started this thread, the syncing on home network no longer works. It looks like I am not the only one with this issue. Have those logs shown anything?
ct002695 0 Posted September 11, 2017 Posted September 11, 2017 Hi I'm experiencing the same issue. Everything used to work fine but now all the downloads just say "Ready to Transfer" and never do! Server version is 3.2.30.0 and the app 2.9.53. When I click on the "Sync" section in the app it reads "No Downloads found. Create download jobs using the download buttons found throughout the app", however from the server side it shows as "Ready to Transfer.
jabadabado 0 Posted September 13, 2017 Posted September 13, 2017 Hi, Any solutioun to this ? I have the same problem on a few of my devices. I am running Emby server version 3.2.30 on windows 10 and Emby for Android Version 2.9.53 on my devices Sony Experia with Android 6.0.1 Working Lenovo TAB 3 A7 with android 5.0.1 Working Asus Zenphone 3 Max with Android 7.1.1 Not Working Samsung Tab 2 8" with Android 4.4.2 not working server-63640898738.txt
0plus6 3 Posted September 18, 2017 Posted September 18, 2017 Any update on this? Still broken. I've also noticed they removed the option to push a download to another device. Oddly, Emby removes it and the competitor adds it.
0plus6 3 Posted September 22, 2017 Posted September 22, 2017 Please try version 2.9.61. Thanks. Upgraded to 2.9.61 and it works! Just downloaded 20 mp4 files without issue. So far, so good! Thank you!
revengineer 142 Posted September 24, 2017 Author Posted September 24, 2017 Luke, I happened to be overseas to test the new android version, and I can confirm that the movies are now transferring to my phone for the first time. Nicely done, thank you! With a little bit more detail, the wireless connection I was using must have been overloaded and I had to restart my VPN connection to my home several times. It seemed that the movie download had to restart every time rather than just resume. The download eventually completed overnight. If my observation is correct, it would be nice to have these downloads resume rather than restart. (With sucking data over hotel networks, every MB is valuable :-) ) Is this possible with a small effort?
Luke 42243 Posted September 24, 2017 Posted September 24, 2017 Thanks for the feedback. Yes resuming downloads would be nice.
iamspartacus 40 Posted September 28, 2017 Posted September 28, 2017 Hey @@Luke, just putting a placeholder here. I sent you a PM of my Android log. Some files download fine and some never finish. The log I sent is the of one that never finishes.
Luke 42243 Posted September 29, 2017 Posted September 29, 2017 Your downloads are trying but failing due to an ssl error. It looks like the device might be rejecting your ssl cert.
Luke 42243 Posted September 29, 2017 Posted September 29, 2017 It starts by trying to connect to your local lan address, which times out, then it switches to the wan address, and that appears to connect but throws an ssl exception.
