nominion 7 Posted August 9, 2017 Posted August 9, 2017 Emby Server Version: 3.2.26.0 Emby Android TV App Vesion: 1.4.36g All of a sudden, direct streaming of Live TV no longer works. It was working fine yesterday and then all of a sudden, playback is very choppy this morning. The stream starts with one second of audio, then I get a black screen. The video starts, but then playback is terrible. If I disable direct streaming in the Emby App on my Shield, playback is fine. Attached is the debug server log and I've uploaded the debug log from the Emby app. Playback of direct streamed Live TV started at 07:18:00 on channel 111. Any help would be appreciated. Thanks!
maegibbons 1287 Posted August 9, 2017 Posted August 9, 2017 No log. What is your tuner source? Krs Mark
ebr 16336 Posted August 9, 2017 Posted August 9, 2017 I couldn't find a log at that time. Perhaps it was 7:28 instead? If so, what happens if you uncheck the option to use VLC for Live TV?
nominion 7 Posted August 9, 2017 Author Posted August 9, 2017 Sorry about that. I will attach the log in a bit. For some reason, it didn't work when I originally posted. The source of the Live TV are the two HDHomeRun Primes that I have. I'm pretty confident the time was 7:18. Once I get the log uploaded you should be able to see the events in the server log. Unchecking the box to direct stream live TV fixes it. I can try enabling direct streaming and disabling using VLC for Live TV when I get home tonight. Strangely, I seem to have this problem every time there is a new release of the Emby client software.
nominion 7 Posted August 9, 2017 Author Posted August 9, 2017 Attaching server debug log. server-63637859718.txt
xXSagaiaXx 25 Posted August 10, 2017 Posted August 10, 2017 I'm having this same issue today as well. I'll post logs tomorrow if needed. S.
Luke 42243 Posted August 10, 2017 Posted August 10, 2017 @@xXSagaiaXx what exact issue were you having? Please discuss an example and attach the information requested in how to report a media playback issue. thanks !
nominion 7 Posted August 10, 2017 Author Posted August 10, 2017 I disabled using VLC for Live TV and enabling direct streaming, got mixed results. When trying to view one stream, it seemed to work, but it took a long time to start the stream. The second stream I tried resulted in audio, but no video. I selected the option to correct the playback, but that caused the app to lock up. I had to reboot my Shield as the close Emby app option that pops up doesn't work.
Luke 42243 Posted August 11, 2017 Posted August 11, 2017 @@nominion can we look at the logs from that second stream? thanks.
nominion 7 Posted August 11, 2017 Author Posted August 11, 2017 Actually, I have direct streaming enabled now with VLC disabled, and it seems to be working OK after a reboot of the server and the Shield. If you'd like me to reproduce the problem again, I certainly can. Let me know.
