Sammy 791 Posted September 30, 2017 Author Posted September 30, 2017 In ET where it says Sign in With Emby Connect. I'd like to (re)associate this particular user with my Emby Connect Account but it seems it already is as it has the cloud symbol
Sammy 791 Posted September 30, 2017 Author Posted September 30, 2017 Wow, @@Luke ! I wasn't expecting a response so quick! The user name is actually TVTime (no spaces)
Luke 42239 Posted September 30, 2017 Posted September 30, 2017 And are you entering the local server credentials or the emby connect credentials?
Sammy 791 Posted September 30, 2017 Author Posted September 30, 2017 I logged in with emby connect as Sammy and I have TVTime set up like this:
Sammy 791 Posted September 30, 2017 Author Posted September 30, 2017 I disabled and re-enabled the skill. Now I see this card:
Sammy 791 Posted September 30, 2017 Author Posted September 30, 2017 I need it to find TVTime on Emby Theater on my HTPC..
Sammy 791 Posted September 30, 2017 Author Posted September 30, 2017 (edited) When I select Player 1 it started playing on the open browser window here on my laptop. Not the right place but some progress. Pretty cool. I hit back and it went to the Server Dashboard. I don't use the Server Dashboard for everyday use. I use TVTime and it has Server disabled for security reasons. How to get Alexa to start playing with TVTime? I have to get going this afternoon but will check back tomorrow. Thanks! Edited September 30, 2017 by Sammy
Sammy 791 Posted September 30, 2017 Author Posted September 30, 2017 Can I have TVTime connected to a different email address or Emby Connect account or can I have it associated with this one I'm using right now? It seems to be the issue.
Luke 42239 Posted September 30, 2017 Posted September 30, 2017 Can I have TVTime connected to a different email address or Emby Connect account or can I have it associated with this one I'm using right now? It seems to be the issue. You can associate it with any Emby Connect account that you want. Does that answer your question?
Sammy 791 Posted September 30, 2017 Author Posted September 30, 2017 You can associate it with any Emby Connect account that you want. Does that answer your question?How to do it, please? Sent from my SM-G930P using Tapatalk
Luke 42239 Posted September 30, 2017 Posted September 30, 2017 you already did it in post #30, so just change that to whatever account you want.
Sammy 791 Posted September 30, 2017 Author Posted September 30, 2017 I logged in with emby connect as Sammy and I have TVTime set up like this: This is how I have it in Emby Server but when I log into ET as Sammy it comes up as the server login and not TVTime. Sent from my SM-G930P using Tapatalk
Sammy 791 Posted September 30, 2017 Author Posted September 30, 2017 Should I create a new Emby Connect Account then associate TVTime with that? Sent from my SM-G930P using Tapatalk
Luke 42239 Posted September 30, 2017 Posted September 30, 2017 comes up as the server login and not TVTime. what do you mean by this?
Sammy 791 Posted October 1, 2017 Author Posted October 1, 2017 It is a different account for the Emby Server vs TVTime for daily use. Sent from my SM-G930P using Tapatalk
Luke 42239 Posted October 1, 2017 Posted October 1, 2017 i still don't understand what you're saying. in emby theater just select sign in with emby connect, and the use the pin code feature to sign in as sammy.
Guest asrequested Posted October 1, 2017 Posted October 1, 2017 (edited) Alexa doesn't seem to be finding the computer you're using. When she lists my devices, she tells me the computer names. So if I have Theater open on my computer, the device is listed as my computer name. In your list of devices, I don't see any computers. This is what mine looks like. The app has to be running for it to be acknowledged. Edited October 1, 2017 by Doofus
Sammy 791 Posted October 1, 2017 Author Posted October 1, 2017 When I sign in as Sammy it loads my server account and not my TVTime account. Sent from my SM-G930P using Tapatalk
Sammy 791 Posted October 1, 2017 Author Posted October 1, 2017 i still don't understand what you're saying. in emby theater just select sign in with emby connect, and the use the pin code feature to sign in as sammy.When I sign in as Sammy it loads my server account and not my TVTime account. Sent from my SM-G930P using Tapatalk
Luke 42239 Posted October 1, 2017 Posted October 1, 2017 What server account are you referring to? TVTime is your server account.
Guest asrequested Posted October 1, 2017 Posted October 1, 2017 If I'm understanding this correctly, you have two accounts. Your main account that you use for server admin, and a user account that you use for general use. Correct? And you want to sign into theater with your user account, but you're having problems with it?
Sammy 791 Posted October 1, 2017 Author Posted October 1, 2017 If I'm understanding this correctly, you have two accounts. Your main account that you use for server admin, and a user account that you use for general use. Correct? And you want to sign into theater with your user account, but you're having problems with it?Exactly. My user account is TVTime but alexa is not connecting to it. Sent from my SM-G930P using Tapatalk
Luke 42239 Posted October 1, 2017 Posted October 1, 2017 Why do you think alexa isn't connecting to it?
