gardar 16 Posted August 8, 2017 Posted August 8, 2017 Just went from 3.2.22.0 to 3.2.26.0 on my Arch Linux based server and now I'm experiencing playback issues I've never experienced before. The video plays for a few seconds at a time and then stops for a few seconds, then continues playing for a few seconds and then stops again. etc. I am experiencing this issue both on Chromecast and with the Android TV app. The server Dashboard shows that the file has been successfully transcoded (the red "Direct Stream" bar is full) Luckily I did take a snapshot of the VM before upgrading, so I was able to roll back to 3.2.22.0 and I can confirm it has no such issues when playing the same file. Can I provide the server logs in a PM to any of the moderators? I'd rather not post them publicly.
gardar 16 Posted August 8, 2017 Author Posted August 8, 2017 Yes you can thanks.Pm sent, thank you. Sent from my SM-N9002 using Tapatalk
Luke 42245 Posted August 9, 2017 Posted August 9, 2017 can you also attach a log from the previous version? thanks.
gardar 16 Posted August 10, 2017 Author Posted August 10, 2017 Sure thing, I have just sent you the logs from 3.2.22
Luke 42245 Posted August 10, 2017 Posted August 10, 2017 The logs are identical. The only difference is one is resuming and one is not, and also you apparently changed ffmpeg versions.
gardar 16 Posted August 11, 2017 Author Posted August 11, 2017 That ffmpeg update might be the culprit then, I upgraded Arch fully and not just emby. I'll update just emby and see if I have the same issue then Sent from my SM-N9002 using Tapatalk
