teddybear75 11 Posted October 9, 2019 Posted October 9, 2019 No. not necessary. Great, thanks, then i will only add it in "Folder"
ebr 16313 Posted October 9, 2019 Posted October 9, 2019 If you are on Windows, I highly suggest using the machine name instead of IP address. Otherwise, if the address were to ever change, everything would break.
teddybear75 11 Posted October 9, 2019 Posted October 9, 2019 (edited) ebr Posted Today, 03:16 PM If you are on Windows, I highly suggest using the machine name instead of IP address. Otherwise, if the address were to ever change, everything would break. Not a bad idea Edited October 9, 2019 by teddybear75
teddybear75 11 Posted October 9, 2019 Posted October 9, 2019 (edited) Question: I am now getting access denied on some paths/files when scanning, is there a way to include user/pass to the network in the Folder path? This was not a problem when the drives were mapped Example: "System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '\\X.X.X.X\Seriesname\Seasonfolder\season.nfo' is denied." Seems i am able to play and scan files, but not write nfo`s or thumbs. Edit: I have tried creating a windows user with the same user and pass on my fileservers, and shared media to this user with all privileges. This is the same user/pass i use on the pc where emby server is on. Hope this will work. Edit 2: Its a windows share problem, not an emby problem, i think i have entered an old username and password earlier, and now when i go to these paths, windows stil remembers this, i will have to find a way to log out of this, or give the old user write permission on my file server. Edit 3: Fixed. Deleted user/pass with windows credentials, rebooted, and now it uses the user i created, all good Edited October 9, 2019 by teddybear75
