zoula 6 Posted August 4, 2017 Posted August 4, 2017 Hi, Is there an option in the kodi plugin to enable a file to be transcoded with all there audio and subtitles tracks. When I start a file that need transcoding it ask which audio and subtitles I whant it to be transcode. The problem is that if I change my mind I need to stop the file playing and start it again with the right settings. i tried the Emby apps on my PC and it allowed me to change the audio and subtitles on the fly.... Is there and setting that I miss somewhere?? Thank you, and keep up your good work!! Zoula
Angelblue05 4132 Posted August 5, 2017 Posted August 5, 2017 Thank you Unfortunately there is no way to change the transcode once it started in Kodi. The player needs to be stopped since the play url changes when you change settings. The only exception are external subtitles, you can change them without any impact on playback.
