pmac 143 Posted August 4, 2017 Posted August 4, 2017 I'm going to be going away without internet access next month, so I thought I'd try out the sync feature on my Windows tablet (proper Windows 10, not RT) and get a few tv shows and movies synced to it in lower quality (to save space on the small 32gb MicroSD card) than I could get by just copying the files directly. Plus, I'd rather use an Emby GUI as an interface while watching media. I've tried both "Sync" and "Download" in the dashboard web app, Emby Theater, and Ember; all with the same problems: Titles seem to get stuck on either queued, or ready to transfer. I've removed and restarted them multiple times, to no avail. the few times I had a notification telling me something completed downloading, when I went offline on my tablet, the files either weren't there, or wouldn't play (black screen). I've tried setting the sync/download folders to my tablets internal storage, as well as an external MicroSD card (preferable, as I don't have much internal storage). Also, I'm a little confused as to the difference between "Sync" and "Download". Which would be preferable in my case, where I'd like to conserve disk space for offline viewing? I don't care which app I use, whether it's Emby Theater, or Ember; as long as I can get it working by next month. Let me know if there's any more information that might help. I've removed all of my sync jobs, so I can start from a clean slate; hopefully with some guidance. Thanks, Patrick
Luke 42203 Posted August 4, 2017 Posted August 4, 2017 If you were able to do it from the web app with Sync then it sounds like you are not running the latest version of Emby Server, so the first thing I would do is update.
pmac 143 Posted August 4, 2017 Author Posted August 4, 2017 If you were able to do it from the web app with Sync then it sounds like you are not running the latest version of Emby Server, so the first thing I would do is update.
Luke 42203 Posted August 4, 2017 Posted August 4, 2017 Right but you can't sync to devices like that. Just use the download functions inside the app.
pmac 143 Posted August 4, 2017 Author Posted August 4, 2017 Right but you can't sync to devices like that. Just use the download functions inside the app. Ah okay, I remember now that it wasn't working when I tried it with the web app... Do you have a suggestion as to which app is more likely to work for me? I've tried "Sync" in Ember, and "Download" in Emby Theater; both options seem to serve the same functionality, despite the "sync" option in Emby Theater having the same issue that it does in the web app (unable to select a device to sync to). I've tried both of these options multiple times already, with the results I described in my original post. I'm trying it again right now though, with one collection being "synced" from Ember, and another collection being "downloaded" from Emby Theater (both on my tablet). Currently the collection I've selected to download through Emby Theater is stuck at "Transferring 0%", and the collection I've selected to sync from Ember is in the process of converting, which I'm confident will either get stuck at "queued", "transferring", or "ready to transfer" once finished converting (this is what happened the other times I've tried).
7illusions 1249 Posted August 4, 2017 Posted August 4, 2017 Hi @@pmac. once the conversion is completed. In Ember, click the user icon in top right corner and then click on sync. In there you should be able to click the "Start Sync" button which should force a sync transfer. This should just work automatically though...
pmac 143 Posted August 4, 2017 Author Posted August 4, 2017 @@Luke everything I've tried to download to my device is still stuck at either "Transferring 0%", "Ready to transfer", or "Queued"... there are a few files in the folder I've set for downloads on my device, but they all report as corrupted when I try to play them in WMP. Any ideas? I only used WMP to test the video files because I didn't want to disconnect from my network to try and play them offline through Emby, and risk messing up part of the transfer process or anything. On previous attempts at downloading for offline play, some files showed up in Emby, but just went to a black screen when I tried to play them.
pmac 143 Posted August 7, 2017 Author Posted August 7, 2017 @@Luke let me know if this log has what you need
pmac 143 Posted August 11, 2017 Author Posted August 11, 2017 Anyone else have any ideas on what my issue might be here? I'd really like to get this working before I go away.
pmac 143 Posted August 16, 2017 Author Posted August 16, 2017 Are you on wifi or out of network? I'm on WiFi
Luke 42203 Posted August 17, 2017 Posted August 17, 2017 @@pmac I would suggest trying the new release of emby server, thanks.
