JulioQc 0 Posted August 4, 2017 Posted August 4, 2017 (edited) Hello, I recently moved from Plex to Emby because the first still doesn't support the Chromecast Ultra but I'm coming across a different problem with Emby: While most video files I have are 5.1 or 7.1 audio tracks and thus require transcoding, which I know is normal for the CCU since it only supports stereo audio or passthrough, I notice Emby transcodes the whole file instead of only the audio... So because the MKV has 5.1 audio, the video is transcoded from HEVC to h264 all the time which obviously uses unnecessary CPU and lowers the quality of the stream. This occurs for any HEVC files I have that includes an audio track over 2 channels... HD or UHD. So is this normal? Did I forget to configure anything? Where can I get more info as to why exactly it's being transcoded? emby_server.log emby_transcoding.log Edited August 4, 2017 by JulioQc
mastrmind11 722 Posted August 4, 2017 Posted August 4, 2017 Hello, I recently moved from Plex to Emby because the first still doesn't support the Chromecast Ultra but I'm coming across a different problem with Emby: While most video files I have are 5.1 or 7.1 audio tracks and thus require transcoding, which I know is normal for the CCU since it only supports stereo audio or passthrough, I notice Emby transcodes the whole file instead of only the audio... So because the MKV has 5.1 audio, the video is transcoded from HEVC to h264 all the time which obviously uses unnecessary CPU and lowers the quality of the stream. This occurs for any HEVC files I have that includes an audio track over 2 channels... HD or UHD. So is this normal? Did I forget to configure anything? Where can I get more info as to why exactly it's being transcoded? check and post the transcode logs from that session.
JulioQc 0 Posted August 4, 2017 Author Posted August 4, 2017 Edited my post to include required logs and a picture of the dashboard status. So you can see it says the transcoding is caused by incompatible audio, which is fine but the video is also converted to h264 for some reason.... This is the video info: Codec HEVC Profile Main 10 Level 150 Resolution 3840x2160 Aspect ratio 16:9 Anamorphic No Interlaced No Framerate 25 Bitrate 34918 kbps Pixel format yuv420p10le Ref frames 1 This is compatible with the CCU I believe but note how the level is detected as 150 instead of 5.0
JulioQc 0 Posted August 4, 2017 Author Posted August 4, 2017 To follow up, I've converted the audio to AAC 5.1 and it direct play now So ya, ok DTS needs transcoding but why is the video transcoded as well? And why not to h265?
Jdiesel 1437 Posted August 4, 2017 Posted August 4, 2017 I don't think this is specific to the Chromecast Ultra as it appears to be the case with Android TV too. https://emby.media/community/index.php?/topic/49577-4k-movies-play-intermittent-on-sony-smart-tv/page-1
maestrozezinho 0 Posted October 18, 2017 Posted October 18, 2017 Hi, This unnecessary transcoding happens with Chromecast 2 also, Log attached. ffmpeg-transcode-214af340-39ed-434e-a473-7bb1cf562fb6.txt&api_key=610ab93f6ccf4448825c52bf403ffc26.txt
Luke 42245 Posted October 18, 2017 Posted October 18, 2017 Hi, This unnecessary transcoding happens with Chromecast 2 also, Log attached. That's not exactly true. The bitrate of your video is over 12mbps. It's well documented that Chromecast can only handle 10-11 mbps, so that is why it's transcoding. For Chromecast Ultra, the limit is much higher.
maestrozezinho 0 Posted October 19, 2017 Posted October 19, 2017 (edited) That's not exactly true. The bitrate of your video is over 12mbps. It's well documented that Chromecast can only handle 10-11 mbps, so that is why it's transcoding. For Chromecast Ultra, the limit is much higher. Plex can cast this file transcoding only the audio. Plex also plays the following file direct streaming the video and transcoding only the audio: General Unique ID : ****************** Complete name : ******************.mkv Format : Matroska Format version : Version 2 File size : 18.2 GiB Duration : 1 h 5 min Overall bit rate mode : Variable Overall bit rate : 40.0 Mb/s Encoded date : UTC 2011-02-17 11:14:07 Writing application : mkvmerge v4.5.0 ('Speed of Light') built on Jan 31 2011 22:54:33 Writing library : libebml v1.2.0 + libmatroska v1.1.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 5 min Bit rate mode : Variable Maximum bit rate : 40.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Title : ************** @ 37976 kbps Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1 h 5 min Bit rate mode : Variable / Constant Bit rate : Unknown / 1 509 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless / Lossy Title : DTS (MA) / 2073 kbps / 48 KHz / 16-Bit / 5.1 Language : English Default : Yes Forced : No Edited October 19, 2017 by maestrozezinho
JulioQc 0 Posted October 20, 2017 Author Posted October 20, 2017 Plex doesn't check if the bitrate is too high before casting. By searching their forum you'll see many people experiencing 'lag' issues because of that. Emby might check that first before casting but I couldn't say for sure.
Luke 42245 Posted October 20, 2017 Posted October 20, 2017 @@JulioQc, this topic was originally about chromecast ultra. The above member has taken us off topic a little by posting about older models, but Chromecast Ultra has a slightly different set of rules and it should be direct playing quite a bit more.
DungHo51 0 Posted April 24, 2018 Posted April 24, 2018 I just recently found out about emby. installed and got premier. I'm very excited to cast my first music video to chromecast ultra. Soon after the cast I got disappointed because of the audio stuttering/lag (DTS 5.1). I'm hoping Emby get this issue resolved soon. I also used Videostream and have no such problem. Emby just have an awesome interface and organization for all the media. I'm hoping to switch over to Emby for good but the audio issue needs to be resolved first. thanks
DungHo51 0 Posted April 25, 2018 Posted April 25, 2018 just found out some more info that emby is direct streaming the file to chromecast with the audio problem. I tried to play it on Plex and had no audio issue. ffmpeg-remux-9a3ddd74-de7b-48bf-aacf-ba088980f339.txt&api_key=c470bbb958114b02ac4c02a112a7f24c.txt
Luke 42245 Posted April 25, 2018 Posted April 25, 2018 Hi, can you try dropping the Chromecast quality setting to 3 mbps? This will force a full video transcode. Please see if that helps. Thanks !
DungHo51 0 Posted April 25, 2018 Posted April 25, 2018 Thanks, i will try later today and report back. although I do prefer direct stream to get the best quality. Any thoughts on what is the cause. I know Plex and Videostream both able to playback DTS 5.1 perfectly fine to my chromecast ultra. Been using all 3 and I like emby best, would rather stay with Emby
Luke 42245 Posted April 25, 2018 Posted April 25, 2018 Well the audio will have to be converted because Chromecast does not support dts. We could potentially try lowering the audio bitrate.
DungHo51 0 Posted April 25, 2018 Posted April 25, 2018 (edited) Luke, tried changing the chromecast to 3mb. It is still not working. Audio sounds broken like yesterday I investigated a little more now that i know the program. Looks like it is transcoding already. So I'm guessing the problem is the transcoder. Edited April 25, 2018 by DungHo51
Luke 42245 Posted April 26, 2018 Posted April 26, 2018 Can you provide the ffmpeg log from that? thanks !
DungHo51 0 Posted April 26, 2018 Posted April 26, 2018 hm.. i thought i attached the log file already. must not have saved to my reply. Will get tonight.
