Swynol 375 Posted August 4, 2017 Posted August 4, 2017 Having some problems with the webapp. most the time the webapp stops playing 30 seconds too early so i often miss the last part of episodes. Also occasionally when playing it will jump back a few minutes and start repeating what i have already seen however the progress bar shows the correct time.
Luke 42203 Posted August 4, 2017 Posted August 4, 2017 Hi there @@Swynol, we're very sorry to hear about your issue. In order for us to best help you, please discuss a specific example and attach the information requested in how to report a media playback issue. thanks !
Swynol 375 Posted August 4, 2017 Author Posted August 4, 2017 (edited) ok thanks. it was doing it on stable 3.2.26.0. i upgraded to Beta and it is still doing it - 3.2.26.13 It happened at 16:25, it jumped back around 5 mins. log.txt ffmpeg.txt Edited August 4, 2017 by Swynol
Luke 42203 Posted August 4, 2017 Posted August 4, 2017 Hi, can you try turning off quicksync encoding and see if the issue persists? thanks.
Swynol 375 Posted August 7, 2017 Author Posted August 7, 2017 with quicksync off everything seems to be fine. wonder why this has only started recently. i've used quicksync for ages.
