chef 3811 Posted February 23, 2014 Posted February 23, 2014 Sorry guys! I can not figure out how to edit my sons library folders to be different from the default library. I realize this is a stupid thing to ask.
ebr 16354 Posted February 23, 2014 Posted February 23, 2014 Wait until the next server release. It will get much easier.
chef 3811 Posted February 23, 2014 Author Posted February 23, 2014 (edited) @@ebr, sorry, so right now it isn't possible through the Server Web UI? I had wondered why my sons library had changed to the default virtual folders. This web page for the server need to be updated: http://mediabrowser.tv/community/index.php?/topic/692-mb3-server-setup-and-configuration/&do=findComment&comment=24081 Edited February 23, 2014 by chef
ebr 16354 Posted February 23, 2014 Posted February 23, 2014 If you are on the dev server now, then you go to the user in question, click "Library Access" and then check off what you want him to see. We are working on updating the tutorial but all of this is in flux right now.
CBers 7576 Posted February 23, 2014 Posted February 23, 2014 (edited) Is that why I'm seeing duplicates in my daughter's profile: and the Trakt plugin: Edited February 23, 2014 by CBers
Luke 42289 Posted February 23, 2014 Posted February 23, 2014 yea the migration isn't perfect and everyone should review their library sharing settings after the upgrade.
ebr 16354 Posted February 23, 2014 Posted February 23, 2014 Yes, but it looks like CBers has the same situation I did with multiple Media Folders with the same name and that doesn't work right now regardless of the migration. Everything gets very confused and access settings won't "take".
CBers 7576 Posted February 23, 2014 Posted February 23, 2014 (edited) I'm getting this in the Default Library as well: Solution ?? Delete library.db and re-scan ?? Edited February 23, 2014 by CBers
Luke 42289 Posted February 23, 2014 Posted February 23, 2014 no just remove the dupes. i have already improved the migration a little for users on the public release but you'll just have to fix it up manually.
CBers 7576 Posted February 23, 2014 Posted February 23, 2014 no just remove the dupes. i have already improved the migration a little for users on the public release but you'll just have to fix it up manually. OK, that looks better.
