pir8radio 1313 Posted July 31, 2017 Posted July 31, 2017 So I'm switching to two HDHomeruns for my live tv. They are not being detected by emby like they used to be... I even tried entering the tuner ip manually yet they don't show up in the list of tuners... Yet from the web browser on the same emby server i can tune into a channel just fine. The only change is that my server is bound to 127.0.0.1 But I didn't think this was for the tuner search as well? Is it? Bind to is just for the emby web server right?
Luke 42243 Posted July 31, 2017 Posted July 31, 2017 If the automatic detection doesn't find it, you can always manually enter the address.
pir8radio 1313 Posted July 31, 2017 Author Posted July 31, 2017 If the automatic detection doesn't find it, you can always manually enter the address. I did, but i still dont see the list of "available tuners" or was that removed? It used to say Tuner 0, Tuner 1, Tuner 2 and their status. I might have to submit some logs...
pir8radio 1313 Posted July 31, 2017 Author Posted July 31, 2017 Well thats a little embarrassing, Its working.. It just looks like you removed the list of available tuners on the live tv tab in the dashboard... Sorry to waste everyone's time.
pir8radio 1313 Posted July 31, 2017 Author Posted July 31, 2017 No that hasn't been removed. Humm.... I am watching live tv, and the Tuner Devices screen shows no available tuners below the "Refresh Guide" button like I remember.. Should I be looking elsewhere?
Luke 42243 Posted July 31, 2017 Posted July 31, 2017 Best thing to do is provide the info requested in how to report a problem. thanks !
Solution maegibbons 1287 Posted August 1, 2017 Solution Posted August 1, 2017 Yes - that section is still there for me on yesterdays beta. What HDHR model and firmware are you running? Krs Mark 1
pir8radio 1313 Posted August 1, 2017 Author Posted August 1, 2017 Yes - that section is still there for me on yesterdays beta. What HDHR model and firmware are you running? Krs Mark Thanks for reminding me to check the firmware of the HDHomerun, that was the issue... Again embarrassing.... I should know better...
