shocker 135 Posted January 28, 2018 Posted January 28, 2018 Interesting topic So basically if you create a cronjob to keep in sync the watch status between the databases should work. I have another question, if you use for example haproxy to LB the load, can the same emby connect user be added to multiple servers in the same time and have the same access key to be able to connect for the same server? Or how this load balancing will work?
pir8radio 1313 Posted January 29, 2018 Posted January 29, 2018 (edited) Interesting topic So basically if you create a cronjob to keep in sync the watch status between the databases should work. I have another question, if you use for example haproxy to LB the load, can the same emby connect user be added to multiple servers in the same time and have the same access key to be able to connect for the same server? Or how this load balancing will work? Load balance would have to keep the user on the same one back end server, or they would have to keep logging into each new server they hit. Nginx calls this "ip-hash" load balancing. Not sure how emby connect would deal with this. Edited January 29, 2018 by pir8radio
