vaise 340 Posted July 28, 2017 Posted July 28, 2017 Suspect this started on the last update, when these recorded tv items got squished also. delete one, it stays there, its not really there tho as you cant watch it again. exit/enter fixes it - they are gone. roku3 and 2, latest FW latest emby and latest app. Nextpvr 4.4, latest plugin. Thanks.
speechles 2062 Posted July 28, 2017 Posted July 28, 2017 I think he means, after deleting recorded tv, the screen doesnt refresh to remove the deleted items tile from the screen. Sent from my Nexus 7 using Tapatalk
vaise 340 Posted July 29, 2017 Author Posted July 29, 2017 (edited) Yep - the screen does not refresh, have to exit emby and enter it again on the roku. We have had this issues the same a while back and it was fixed - I think I reported it then too. Edited July 29, 2017 by vaise
ebr 16335 Posted July 29, 2017 Posted July 29, 2017 Does it work properly when deleting content outside of NextPVR (e.g. a regular video file)?
vaise 340 Posted August 12, 2017 Author Posted August 12, 2017 I have never needed / wanted to delete any other media - only recorded TV. I can do a test after saving something I guess.
blade005 185 Posted August 18, 2017 Posted August 18, 2017 (edited) Does it work properly when deleting content outside of NextPVR (e.g. a regular video file)? @@ebr I use native Emby Live TV and it does work when deleting Recorded TV content. But, it does require a bit of patience. After deleting the item from the episode detail screen you are returned to the Emby Roku HOME screen and the item is still present. The refresh and removal of the item from the HOME screen that has been deleted can take 5 - 10 seconds. UPDATE: The Deleted Recordings do refresh in the LATEST SHOWS section of the HOME screen, but they are not removed from the LATEST RECORDINGS section of HOME screen until you exit Emby and then open it again. Edited August 19, 2017 by blade005
vaise 340 Posted August 19, 2017 Author Posted August 19, 2017 This is working again now - I don't know the reason for it through. I have started to use the beta channel however over the normal one - as that also fixed the squished icons.
