Luke 42203 Posted August 3, 2017 Posted August 3, 2017 keep in mind this is only going to impact emby connect, if the server can't detect the local network address then it won't have one to report to emby connect. however, if you're on a different device that doesn't prevent you from manually entering an address if you happen to know it.
Guest asrequested Posted August 3, 2017 Posted August 3, 2017 The two areas I would look at/test, would be you NIC or your switch. One of them may be having issues.
