Saltyzip 0 Posted December 19, 2017 Posted December 19, 2017 I assumed it was sorry. I've not seen any notification asking for upgrade so will take a look now to see how to fix.
Luke 42239 Posted December 19, 2017 Posted December 19, 2017 We temporarily paused automatic updates. What you can do is just run the installer from the website on top of your existing installation. Thanks.
Saltyzip 0 Posted December 19, 2017 Posted December 19, 2017 We temporarily paused automatic updates. What you can do is just run the installer from the website on top of your existing installation. Thanks. Ahh ok - I hadn't realised my Version 3.2.36.0 was out of date as emby dashboard, says it is up to date. I'll download new version manually now as got sidetracked a little earlier with a new hamster joining the family.
Saltyzip 0 Posted December 19, 2017 Posted December 19, 2017 Ok, so I am now running Emby Version 3.2.50.0 - I will re-run the earlier test now. Also the chromecast firmware version I'm running is 1.29.104827
Saltyzip 0 Posted December 19, 2017 Posted December 19, 2017 Exact same issue again at the 22 min mark, running latest emby server. Anything else you need from me? I am trying to make available a 30 min sample of this blu-ray to aid your debugging, although it's 5 gig so not so easy to share, perhaps you have an ftp site I can upload it too? I probably should test the issue is replicated with the sample file too. ffmpeg-remux-903e2b99-7a25-4189-b128-a6e162678bdd.txt server-63649316073.txt
Luke 42239 Posted December 19, 2017 Posted December 19, 2017 yea, dropbox or google drive would be great. just be sure to confirm that the issue also happens with the sample. thanks.
Saltyzip 0 Posted December 19, 2017 Posted December 19, 2017 (edited) Here is the link to sample, it might still be uploading so could get error accessing: https://drive.google.com/file/d/1Jxm6ppBhn8q-Jys_N5GpMoRmh5EQo8ef/view?usp=drivesdk Edited December 19, 2017 by Saltyzip
Saltyzip 0 Posted December 20, 2017 Posted December 20, 2017 (edited) A bit horse before cart, but I've just tested the sample and it went straight through, played all 30 mins on the Chromecast. Not sure if you can learn anything from that. Edited December 20, 2017 by Saltyzip
Barlog9511 17 Posted December 20, 2017 Author Posted December 20, 2017 A bit horse before cart, but I've just tested the sample and it went straight through, played all 30 mins on the Chromecast. Not sure if you can learn anything from that. Hi, do you use subtitles?
Saltyzip 0 Posted December 20, 2017 Posted December 20, 2017 (edited) Hi, do you use subtitles? Not on this movie, and it's direct playing which is correct. I've copied movie file to a sample library folder monitored by emby and have the same issue. I'm not sure how many movies of mine suffer the same issue with emby, as I am still mostly using plex, still contemplating the switch. I'll try and upload the full movie to google drive and share it via private PM, hope that is ok, if not let me know. Edited December 20, 2017 by Saltyzip
Saltyzip 0 Posted December 20, 2017 Posted December 20, 2017 (edited) Hi Luke, I've just private messaged you the link to the movie file for testing the 22 minute stopping issue on my chromecast v2. Hope it helps you reproduce the issue and move forward to provide a fix. Thanks S. Edited December 20, 2017 by Saltyzip
Luke 42239 Posted December 21, 2017 Posted December 21, 2017 Try to play that one again. it should play a little differently now, thanks.
Saltyzip 0 Posted December 21, 2017 Posted December 21, 2017 Have you made a back end change, so nothing I need to update/tweak on my side?
Saltyzip 0 Posted December 21, 2017 Posted December 21, 2017 (edited) Same issue I'm afraid Luke, stopped at 22 minutes like before. Did you download the movie and test in house? Edited December 21, 2017 by Saltyzip
Luke 42239 Posted January 4, 2018 Posted January 4, 2018 Have you tested again recently? I've had your sample video playing for 22 minutes and counting, and no problems. I made sure to select the same audio track you had selected in your previously supplied log file.
Saltyzip 0 Posted January 17, 2018 Posted January 17, 2018 Is there anything more you can do to help me on this one?
Luke 42239 Posted January 17, 2018 Posted January 17, 2018 have you updated to the latest version of emby server?
Saltyzip 0 Posted January 17, 2018 Posted January 17, 2018 I'm currently running Version 3.2.60.0 is that the latest version I should be using as I think there is a later beta version?
Luke 42239 Posted January 17, 2018 Posted January 17, 2018 That's fine. That's the latest stable. We're about to release a new stable so please try that once available. Thanks.
Saltyzip 0 Posted January 29, 2018 Posted January 29, 2018 I've tried latest version and still have same issue.
Luke 42239 Posted January 29, 2018 Posted January 29, 2018 I apologize but i've tried your test media and haven't reproduced. i wonder if it's related to your ffmpeg build because on freebsd we don't bundle it inside the package, therefore we're at the mercy of whatever version is installed on your system.
Saltyzip 0 Posted January 29, 2018 Posted January 29, 2018 I'm running emby on Windows Server 2012 R2 Essentials. I assumed emby installed ffmpeg, is that not a valid assumption? The same server has Plex installed and VLC player too.
Luke 42239 Posted January 29, 2018 Posted January 29, 2018 Sorry I had forgotten. This topic is in the FreeBSD section so it was just an assumption on my part.
