arkx82 0 Posted July 26, 2017 Posted July 26, 2017 hello. I would like to use the tvheadend client, but I want to record through emby.(Native) so I am setting.... I did use antennas docker (like tvhproxy) and I did setup plex dvr through antennas (port 5004) so I can live tv and recording in plex but in case emby... I did select hd homerun. and I write IP(ex 192.168.1.8:5004) and It is added. and I did add xmltv.xml but I can't map channels.. please help me.. or guide.. live_tv.log
haraldov 10 Posted December 23, 2017 Posted December 23, 2017 (edited) Maybe to late answer, but antennas works great for me without docker implementation. I followed the notes the developer made here: https://github.com/TheJF/antennas Ubuntu 16.04 x64 with Emby server 3.2.60.0 .net # Create a directory to store antennas, i.e. mkdir antennas $ mkdir -p /home/hts/antennas/ # Install crystal Link: https://crystal-lang.org/docs/installation/on_debian_and_ubuntu.html $ sudo curl https://dist.crystal-lang.org/apt/setup.sh | sudo bash # Download a Linux release of antennas inside Antennas directory $ cd antennas/ $ git clone https://github.com/TheJF/antennas.git $ cd antennas/ # Install Crystal dependency hts@vdrsrv:~/antennas$ shards install hts@vdrsrv:~/antennas$ shards update # Compile antennas.cr hts@vdrsrv:~/antennas$ crystal build ./src/antennas.cr # Configure your antennas server. Edit config.yml $ nano config/config.yml # Edit the correct ipadresse for your tvheadend server and antennas url. # I have emby server, tvheadend server and antennas on the same server. # Check if the url: http://admin:admin@192.168.9.2:9981 to tvheadend works with the tvheadend admin user and password admin. # If not make a user with admin rights in tvheadend web interface tvheadend_url: http://admin:admin@192.168.9.2:9981 antennas_url: http://192.168.9.2:5004 tvheadend_weight: 300 # subscription priority tuner_count: 4 # numbers of tuners in tvheadend # Run ./antennas as the tvheadend user hts@vdrsrv:~/antennas$ ./antennas # Check antennas is working http://192.168.9.2:5004/ # In Emby server setup the antennas server Emby server --> Live TV Tuner Setup --> Tuner Ip adresse: http://192.168.9.2:5004 # Check with Emby theater if the channels works Edited December 23, 2017 by haraldov
haraldov 10 Posted December 23, 2017 Posted December 23, 2017 (edited) If you want antennas to start as a systemd service via hts user and start on boot you can do it like this: # Make antennas systemd service file in /lib/systemd/system hts@vdrsrv:/$ cd /lib/systemd/system hts@vdrsrv:/lib/systemd/system$ sudo nano antennas.service # Paste this content in the antennas.service and save the file [Unit] Description=HDHomeRun emulator for Plex DVR to connect to Tvheadend After=network.target [Service] WorkingDirectory=/home/hts/antennas/ ExecStart=/home/hts/antennas/antennas Restart=always User=hts [Install] WantedBy=multi-user.target # Test the antennas service hts@vdrsrv:/lib/systemd/system$ sudo systemctl start antennas.service # Access antennas url with your choosen webbrowser http://192.168.9.2:5004/ # If ok then enable the service at boot hts@vdrsrv:/lib/systemd/system$ sudo systemctl enable antennas.service Edited December 23, 2017 by haraldov
Luke 42243 Posted December 23, 2017 Posted December 23, 2017 Can you describe your channel mapping problem in more detail? Thanks.
