bwong3351 0 Posted July 24, 2017 Posted July 24, 2017 First and foremost, Emby is an excellent product. Please keep up the good work. However, I did ran into an issue with transcoding rmvb files recently. The transcoding log all end with a "ffmpeg unknown input format 'rmvb': C:\<some location>\Roaming\Emby-Server\ffmpeg\20170308\ffmpeg.exe -f rmvb -codec:0 aac -i file:"somefile.rmvb" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:1 -map 0:0 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 3829632 -bufsize 7659264 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1920)/2)*2:trunc(ow/dar/2)*2" -copyts -vsync -1 -codec:a:0 copy -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\<somelocation>\transcoding-temp\e747c6a70c9695bd936ce985f1927428.m3u8" -y "C:\<somelocation>\transcoding-temp\e747c6a70c9695bd936ce985f1927428%d.ts" ffmpeg version N-83781-g3016e91 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 6.3.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zlib libavutil 55. 48.100 / 55. 48.100 libavcodec 57. 82.102 / 57. 82.102 libavformat 57. 66.103 / 57. 66.103 libavdevice 57. 3.100 / 57. 3.100 Please let me know if additional information is needed. Thanks in advance.
Luke 42202 Posted July 24, 2017 Posted July 24, 2017 We'll resolve this for the next release, thanks.
