tdiguy 99 Posted July 24, 2017 Posted July 24, 2017 I am having issues updating emby, i think i found the underlying issue. This was the original error: W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://download.opensuse.org Release: The following signatures were invalid: KEYEXPIRED 1500755520 W: Failed to fetch http://download.opensuse.org/repositories/home:/emby/xUbuntu_14.04/Release W: Some index files failed to download. They have been ignored, or old ones used instead. So I ran: pi@raspberrypi:~ $ apt-key list I noticed: 2015-05-14 [expired: 2017-07-22] uid home:emby OBS Project <home:emby@build.opensuse.org> so i tried running: apt-key adv --keyserver keys.gnupg.net --recv-keys <key inserted here> but i got: "home:emby OBS Project <home:emby@build.opensuse.org>" not changed gpg: Total number processed: 1 gpg: unchanged: 1 I am not really sure what to do from here as a work around. When i try doing sudo apt-get install emby it says its at current rev.
rdameron 0 Posted July 24, 2017 Posted July 24, 2017 I have suddenly received the same error. I also tried to update the key and got the additional error communication failed, unknown pubkey alogrithm. The expiration date for the key is listed as yesterday 2017-7-22. Does anyone know why the key won't update?
Luke 42245 Posted July 24, 2017 Posted July 24, 2017 It's being looked into. Thank you for your patience.
rdameron 0 Posted July 24, 2017 Posted July 24, 2017 I am using Ubuntu 16.04 and is causing an internal error because the key has expired so it keeps locking up my kodi. So until there is a fix this shuts down my use of kodi and emby and since we use that as our only TV/Movie source this is a problem. I would very much appriciate any info as soon as anyone has any. Thanks.
Luke 42245 Posted July 24, 2017 Posted July 24, 2017 I am using Ubuntu 16.04 and is causing an internal error because the key has expired so it keeps locking up my kodi. So until there is a fix this shuts down my use of kodi and emby and since we use that as our only TV/Movie source this is a problem. I would very much appriciate any info as soon as anyone has any. Thanks. Hi, this key has nothing to do with Kodi. The only thing it is doing is preventing you from updating to the new release of Emby Server. You should be able to continue to run the previous release you were running on without any problems. Please let us know if this helps. If you still have an issue, then please see how to report a problem. Thanks !
rdameron 0 Posted July 24, 2017 Posted July 24, 2017 Hi, this key has nothing to do with Kodi. The only thing it is doing is preventing you from updating to the new release of Emby Server. You should be able to continue to run the previous release you were running on without any problems. Please let us know if this helps. If you still have an issue, then please see how to report a problem. Thanks ! Just for the record that should be true in theory however in practice when the interl error occours it throws a the error flag which causes a memory issue and locks up kodi making it unresponsive and causing the system to become unstable as the memory can no longer be released until the system is restarted.
rdameron 0 Posted July 24, 2017 Posted July 24, 2017 Ok maybe this will help other people out with the same issue I had. I found that by disabling all automatic downloading and or installing of the updates stops the system errors and the system now seems to be running stable but still has the expired key issue.
thatoneguy99 33 Posted July 24, 2017 Posted July 24, 2017 This worked for me. Just follow the key part of the install for whatever version you're on. https://software.opensuse.org/download.html?project=home%3Aemby&package=emby-server Sent from my phone!
siteripper2 0 Posted July 24, 2017 Posted July 24, 2017 Hello, I also have the problem that on XBOX or Android App it says that I need to upgrade to Premium (though I got a lifetime subscription for 3.x). That error occured a few days ago. When I try to upgrade the repository I also get this error: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://download.opensuse.org/repositories/home:/emby/xUbuntu_16.04 Release: The following signatures were invalid: KEYEXPIRED 1500755520 I hope this will be fixed soon
henryford 11 Posted July 24, 2017 Posted July 24, 2017 Just for the record that should be true in theory however in practice when the interl error occours it throws a the error flag which causes a memory issue and locks up kodi making it unresponsive and causing the system to become unstable as the memory can no longer be released until the system is restarted. What? You should totally look into that because there is no way this should happen because a signature on a package in the repositories expired. Apt will not lock up your memory because of an expired signature - what are you doing in Kodi that this would lock it up?
tdiguy 99 Posted July 24, 2017 Author Posted July 24, 2017 (edited) This worked for me. Just follow the key part of the install for whatever version you're on. https://software.opensuse.org/download.html?project=home%3Aemby&package=emby-server Sent from my phone! I can confirm at least for me using the commands from this section: wget -nv http://download.opensuse.org/repositories/home:emby/Debian_Next/Release.key -O Release.key sudo apt-key add - < Release.key sudo apt-get update Updated the key 2015-05-14 [expires: 2019-09-16] uid home:emby OBS Project <home:emby@build.opensuse.org> I can now update. Thank you. Edited July 24, 2017 by tdiguy 2
Luke 42245 Posted July 24, 2017 Posted July 24, 2017 OBS keys expire every two years so what you will need to do is go back to the download page of our website and do the first part of the installation process again, the part where you setup an OBS key. After that you will be able to update. Thanks. 2
markofealing 0 Posted July 25, 2017 Posted July 25, 2017 Just upgraded Emby on Ubuntu 16.04 using tdiguy's suggestion above wget -nv http://download.opensuse.org/repositories/home:emby/Debian_Next/Release.key -O Release.key sudo apt-key add - < Release.keysudo apt-get update Worked okay
tdiguy 99 Posted July 25, 2017 Author Posted July 25, 2017 Just to be sure i give credit where credit is due i had followed the suggestion from thatoneguy99 I simply posted an excerpt from the directions on the link he posted. Ultimately the devs already had the solution to this issue posted.
thatoneguy99 33 Posted July 25, 2017 Posted July 25, 2017 Haha. I appreciate that. I actually found the solution this in an old thread. Someone was having problems with the install and the key update was the issue. Tried it and it worked. Sent from my phone!
