ewalkersc 8 Posted July 20, 2017 Posted July 20, 2017 After recording live tv, the recording does not include any parental rating information for use by parental control. This data exists in the nfo file as provided by schedules direct, but it's not included in the file or used by Emby anywhere. The recording shows as having no rating.
ewalkersc 8 Posted July 20, 2017 Author Posted July 20, 2017 I have a child account with parental control that is set to not show unrated recordings. The child account can't see any recordings. Where would it be set or used?
Luke 42243 Posted July 20, 2017 Posted July 20, 2017 It sounds like it doesn't have a rating. Have you tried assigning a rating manually?
ewalkersc 8 Posted July 20, 2017 Author Posted July 20, 2017 No I have not Do you want me to try that to see if the rating shows up or is that a proposed solution? I do not want to have to manually set ratings on all recordings. I have TV series in my library with ratings that work fine and use ratings on TV channels themselves that work. I would expect the recording to incorporate the provided rating information somewhere automatically.
Luke 42243 Posted July 20, 2017 Posted July 20, 2017 We do save the rating from the guide data of there was any. It sounds like for this program there wasn't so you'll need to set a rating manually.
ewalkersc 8 Posted July 20, 2017 Author Posted July 20, 2017 I see the rating info in the .nfo file in the same directory, but where does emby look for the rating info. Should it be in the mkv metadata or the .nfo file?
Luke 42243 Posted July 20, 2017 Posted July 20, 2017 Why do you think the nfo has a rating? What do you see there?
ewalkersc 8 Posted July 20, 2017 Author Posted July 20, 2017 It's an XML with all the episode info. Rating, original air date, synopsis, etc
ewalkersc 8 Posted July 20, 2017 Author Posted July 20, 2017 I'll send it to you later when I get home.
ebr 16336 Posted July 21, 2017 Posted July 21, 2017 Live TV has a bunch of strange ratings associated with it like "APPROVED". More than likely, whatever is being provided in the data is not recognized by Emby.
Solution ewalkersc 8 Posted July 26, 2017 Author Solution Posted July 26, 2017 After playing with this some more, it does appear to work. Sorry 1
