mastermind42 1 Posted July 19, 2017 Posted July 19, 2017 I have tried everything to make emby's permission work. I changed the user permission so Emby was the owner of the folder and added adm to there groups but it still can't find the folder. Has anyone figured it out?
Luke 42245 Posted July 19, 2017 Posted July 19, 2017 What do you mean by "it can't find the folder" ?
mastermind42 1 Posted July 19, 2017 Author Posted July 19, 2017 (edited) What do you mean by "it can't find the folder" ? When I navigate to /media/my_name/external_hard_drive_1 it doesn't see any folders inside of it. Also my folders inside the hard drive's owner is "Emby Server default user" and my group is "users". Permissions is drwxrwxrwx Edited July 19, 2017 by mastermind42
mastermind42 1 Posted July 20, 2017 Author Posted July 20, 2017 I am trying to point my emby to an external hard drive that has the correct permissions. However, when I navigate to /media/<myname>/hard_drive_1, there is nothing inside of it. There isn't even the 3 dots that lets me navigate back up one in the directory.
Luke 42245 Posted July 20, 2017 Posted July 20, 2017 @@mastermind42 can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
SkyBehind 23 Posted July 21, 2017 Posted July 21, 2017 Can you get to it in the command line or in your GUI interface? When you're in the folder on the external hard drive, do you see the files? Reason I ask, because it may not be mounted. If you've saved the mount, the folder will be there, but no files inside it. If you set it to automatically mount, did you do it by partition ID or by disk location? Disk location can change if you plugged it into a different port. Just food for thought.
