chef 3811 Posted July 16, 2017 Posted July 16, 2017 Love ember! It's fantastic! But I am finding it hard to follow the highlighted icons in the screen because the highlight-cursor gets lost easily in the color scheme. For instance following the cursor up to the hamburger icon can be difficult if the the highlighted target starts on the bottom d the screen. 1
7illusions 1249 Posted July 17, 2017 Posted July 17, 2017 Is it just the accentcolor that's a problem? In that case, can you try any of the other themes and see how that plays out? Also, can you provide some screenshots with some doodling on top with detailed information? TIA
chef 3811 Posted July 17, 2017 Author Posted July 17, 2017 (edited) Where may I find themes? Is it in the UI? I haven't got that far yet. Did I mention that it's awesome! Edited July 17, 2017 by chef
7illusions 1249 Posted July 17, 2017 Posted July 17, 2017 Thanks. The themes are under settings. (User icon in top right corner -> personalization) Once you've saved, a restart of the app is required at the moment due to a bug where some views won't swallow the change fully. 1
arrbee99 1836 Posted July 27, 2017 Posted July 27, 2017 Just to add to this, maybe it the dark(ish) blue stuff (back arrow, 'M', music note in this case) at the top, which is a bit uncontrasty...
