miniz98 73 Posted July 16, 2017 Posted July 16, 2017 Hey so i set up a m3u tuner and added a .xml.gz for the guide data. I think its not pulling in the guide data because the channel numbers dont match. It pulls in the channel numbers from the m3u file backend. Is there a way to get the guide data to populate. It pulls in the channels the logos but no guide.
Luke 42243 Posted July 16, 2017 Posted July 16, 2017 Hi, have you tried using the channel mapping feature?
miniz98 73 Posted July 16, 2017 Author Posted July 16, 2017 Yes doesnt show any channels? Maybe im in the wrong area?
miniz98 73 Posted July 16, 2017 Author Posted July 16, 2017 Figured it out. How do you remove channels that you don't want in the guide.
CBers 7554 Posted July 16, 2017 Posted July 16, 2017 Figured it out. How do you remove channels that you don't want in the guide. Delete them from your M3U file.
miniz98 73 Posted July 16, 2017 Author Posted July 16, 2017 Is there a way to back up all the hard work setting up the meta data and configurations?
Luke 42243 Posted July 17, 2017 Posted July 17, 2017 hi @@miniz98, in regards to m3u, what metadata do you mean exactly? thanks !
