Angelblue05 4132 Posted July 23, 2017 Posted July 23, 2017 That's not in the wiki. But do you believe adding it will resolve the situation? Let me know. Sent from my iPhone using Tapatalk
pir8radio 1313 Posted July 23, 2017 Posted July 23, 2017 (edited) That's not in the wiki. But do you believe adding it will resolve the situation? Let me know. Sent from my iPhone using Tapatalk I don't know the programming end of things, but that is what i see on the client side web gui... Will it translate to breaking or working on the plugin? I have no clue.. lol But with the /embywebsocket it makes setting up a reverse proxy the way the OP wanted to, much easier. Edited July 23, 2017 by pir8radio
Angelblue05 4132 Posted July 23, 2017 Posted July 23, 2017 Ok, I had no idea this existed, the wiki shows wss://{server}?api=x. I'll make a build with this small modification. Sent from my iPhone using Tapatalk
Angelblue05 4132 Posted July 23, 2017 Posted July 23, 2017 (edited) Can either one of you test this build (install from zip in Kodi). Let me know if it works with your reverse proxy. Thanks! I've changed the websocket url to wss://{server}/embywebsocket?api=x&deviceId=x plugin.video.emby-2.3.49a.zip Edited July 23, 2017 by Angelblue05
pir8radio 1313 Posted July 23, 2017 Posted July 23, 2017 (edited) Can either one of you test this build (install from zip in Kodi). Let me know if it works with your reverse proxy. Thanks! I've changed the websocket url to wss://{server}/embywebsocket?api=x&deviceId=x @@KarmaPolice can you test? You will probably have to create a location based on /embywebsocket if not let me know and ill try it. I only have kodi installed for testing, ill have to update and then add the sections to my nginx config since i use a sub domain setup.. Edited July 23, 2017 by pir8radio 1
