nb0023 0 Posted July 15, 2017 Posted July 15, 2017 My library is not updating after a tv show is added. I have tried installing and reinstalling and the initial library scan works but it doesn't update after. I have emby installed on a windows 7 PC Log: https://pastebin.com/m7t5PwXh
Luke 42202 Posted July 15, 2017 Posted July 15, 2017 Why do you think it isn't updating? Can you discuss that more please? Thanks.
nb0023 0 Posted July 15, 2017 Author Posted July 15, 2017 Why do you think it isn't updating? Can you discuss that more please? Thanks. I use sonarr to download shows. After downloading sonarr sends a notification to emby that a show has been downloaded. I can see the show in folders but it doesnt show up on the emby dashboard or in kodi.
PrincessClevage 175 Posted July 15, 2017 Posted July 15, 2017 I use sonarr to download shows. After downloading sonarr sends a notification to emby that a show has been downloaded. I can see the show in folders but it doesnt show up on the emby dashboard or in kodi.Possibly realtime monitoring not working? I have another thread with similar issue
nb0023 0 Posted July 15, 2017 Author Posted July 15, 2017 Possibly realtime monitoring not working? I have another thread with similar issue Is there anyway to check if its not working? Like in the debug log I posted
PrincessClevage 175 Posted July 15, 2017 Posted July 15, 2017 (edited) Is there anyway to check if its not working? Like in the debug log I postedi have been attempting to figure out the same thing"Just click on the library in library setup and check that the real-time monitor option is checked" More options for scheduled Libary scan https://r.tapatalk.com/shareLink?share_type=t&share_fid=77624&share_tid=38241&url=https%3A%2F%2Femby%2Emedia%2Fcommunity%2Findex%2Ephp%3F%2Ftopic%2F38241-More-options-for-scheduled-Libary-scan Edited July 15, 2017 by PrincessClevage
Luke 42202 Posted July 15, 2017 Posted July 15, 2017 He's using the sonarr notification so he doesn't need the real-time monitor. Where are you looking for the episode in the emby server dashboard?
nb0023 0 Posted July 15, 2017 Author Posted July 15, 2017 i have been attempting to figure out the same thing "Just click on the library in library setup and check that the real-time monitor option is checked" More options for scheduled Libary scan https://r.tapatalk.com/shareLink?share_type=t&share_fid=77624&share_tid=38241&url=https%3A%2F%2Femby%2Emedia%2Fcommunity%2Findex%2Ephp%3F%2Ftopic%2F38241-More-options-for-scheduled-Libary-scan Thanks. I'll take a look at that He's using the sonarr notification so he doesn't need the real-time monitor. Where are you looking for the episode in the emby server dashboard? Under "my media" in the "TV" folder
Luke 42202 Posted July 15, 2017 Posted July 15, 2017 As a baseline, have you tried running a library scan?
nb0023 0 Posted July 15, 2017 Author Posted July 15, 2017 As a baseline, have you tried running a library scan? Yes, multiple times. I just did a fresh re-install yesterday but on my old setup the episodes would sometimes show up in my library a day or two later.
Luke 42202 Posted July 15, 2017 Posted July 15, 2017 can you show us a screenshot of the actual folders on your drive so that we can see the files in the folder? and then can you show the corresponding screen in Emby so that we can compare? thanks !
