lalascott71 0 Posted July 14, 2017 Posted July 14, 2017 What is the purpose of Emby connect? To enable you to connect to the server on the cloud without using your computer? Sent from my SM-J327P using Tapatalk
mastrmind11 722 Posted July 14, 2017 Posted July 14, 2017 What is the purpose of Emby connect? To enable you to connect to the server on the cloud without using your computer? Sent from my SM-J327P using Tapatalk No, it's to easily authenticate w/o having to remember the server's address. 1
ebr 16309 Posted July 14, 2017 Posted July 14, 2017 And, to provide a much easier authentication method for TV (remote control operated) interfaces because you just enter a numeric PIN instead of complex password. 1
Luke 42202 Posted July 14, 2017 Posted July 14, 2017 @@lalascott71, to learn more, please check out our wiki on Emby Connect: https://github.com/MediaBrowser/Wiki/wiki/Emby%20Connect Please let us know if this helps. Thanks ! 1
lalascott71 0 Posted July 14, 2017 Author Posted July 14, 2017 No, it's to easily authenticate w/o having to remember the server's address.Thanks. [emoji2] Sent from my SM-J327P using Tapatalk
