billy24752 0 Posted July 13, 2017 Posted July 13, 2017 any help appreciated. about 6 months ago i changed my broadband provider to Plusnet, this enabled my house to get much quicker internet speeds of up to 12Mbpsnow i know to a lot of you this is still incredibly slow but compare that to when I was struggling to achieve 2Mbps it feels like lightning. anyway, I used to stream my emby content via my Android phone to the tv in my bedroom via Chromecast, this worked fine. I need to use a signal Booster for my WIFI as I have a townhouse and my bedroom is on the top floor whereas my server is on the ground floor so in effect 3 floors apart. however since getting the faster service there has been nothing but problems with this service, last night I tried watching a movie and it continually stopped started, I have done a speed test on the WIFI signal in my room and it averages out at around 8Mbps my PC which is hardwired gets 13Mbps. I have the latest updates on my phone, both software and operating system, the Chromecast has no issue playing HD YouTube clips, like I said any help much appreciated, I bloody love Emby and don't want to have to stop using it. cheers
Luke 42202 Posted July 13, 2017 Posted July 13, 2017 Hi there @@billy24752, we're very sorry to hear about your playback issue. We'd like to help you resolve it. In order for us to do that, please discuss a specific example, and then accompany that example with the information requested in how to report a media playback issue. thanks !
billy24752 0 Posted July 13, 2017 Author Posted July 13, 2017 thank you, its difficult to explain in finite detail, basically when i load up the Emby app on my Sony Xperia Premium the app loads okay, i press the cast button and this is when it sometimes puts the emby screen on to the TV sometimes it doesn’t. when it comes to playing the file it will either circle for a long time and nothing happens or the file will look as though it will play but then it just plays stop start so slow you cant hear any words the actors are saying as it breaks down each syllable I have attached the log as requested
billy24752 0 Posted July 14, 2017 Author Posted July 14, 2017 i thought i had atatched it but io will try agaon server-63635500800.txt
Luke 42202 Posted July 14, 2017 Posted July 14, 2017 hi @@billy24752, in this log it appears you're playing from Emby Theater, right? I do not see any Chromecast or android playback here. Is this the right log?
billy24752 0 Posted July 16, 2017 Author Posted July 16, 2017 hi, that was the latest log i had available. I have attached a new Log I have no idea what its going on about I scrolled down to near the bottom and it states Xpria XZ premium so hopefully that will be what's required. my set up is Emby Theatre on my PC which I have attached to my main Television. then I leave the PC on with Emby server playing tp enable me to access my movie library via my phone then cast the movie to the TV in my bedroom./ server-63635587202 to Use.txt
Luke 42202 Posted July 18, 2017 Posted July 18, 2017 hi @@billy24752, are you saying you cast to the TV in the bedroom using Chromecast? I ask because even in your most recent log I do not see any connectivity from any Chromecast devices. Can you explain what exactly happened? thanks !
billy24752 0 Posted July 18, 2017 Author Posted July 18, 2017 sorry thought I had explained it but obviously not. I play the media via my mobile and cast it to my TV using the google Chromecast, the issues when they arise is that the TV shows/movies stop start when they play literally not playing continuously for more than 2 sec's. I will try and look for another log which may help. will they be in the main log folder or do I need to look somewhere else?
billy24752 0 Posted July 18, 2017 Author Posted July 18, 2017 this is the latest log server-63635932800.txt
Luke 42202 Posted July 18, 2017 Posted July 18, 2017 Can you open the web app detail screen for one of these videos and copy and paste the media info from the bottom of the screen and supply it here? thanks.
billy24752 0 Posted July 20, 2017 Author Posted July 20, 2017 sorry mate I am being a bit thick, what do you mean. treat me like you would a small child
Luke 42202 Posted July 20, 2017 Posted July 20, 2017 Are you able to locate the video in the emby web app? I presume yes since that is where you are casting from right?
billy24752 0 Posted July 20, 2017 Author Posted July 20, 2017 i can play the video on my phone but what info do you want copy and pasted?
Luke 42202 Posted July 20, 2017 Posted July 20, 2017 I want to see the information located at the bottom of the detail screen from the phone. It's under the Media Info heading. Do you see that?
billy24752 0 Posted July 20, 2017 Author Posted July 20, 2017 I couldn’t find the file that you are talking about so I attached two screen grabs not sure if this will help
Luke 42202 Posted July 20, 2017 Posted July 20, 2017 I would suggest going into app settings for the casting app and setting the max chromecast bitrate to 1mbps. If that successfully plays, then you can continue to raise it until you encounter a problem. I think our defaults on Auto are probably just too aggressive for your network. thanks.
Luke 42202 Posted July 20, 2017 Posted July 20, 2017 Ok thanks, yes that was it. Please try my advice in post #18. Thanks.
billy24752 0 Posted July 20, 2017 Author Posted July 20, 2017 I will give it a go, many thanks for your assistance
