no web interface access on freenas
Hi,
I was using emby on my WinX-machine for some weeks now and wanted to try to install it as a jail-installation on my freenas-server. I managed to install the jail, it is running, I can ping to it and from a terminal within the jail to other machines in my network but I can't connect to the webinterface. I tried the usual stuff like ip:8096 and ip:8096/web/wizardstart.html but with no luck.
Any ideas how to get this working or how to connect to the web interface? Do I have to start any services from within the jail? Is there any manual for the jail-installation?
Cheers,
v4rg
found it - forgot to active emby in the add-on-section (the red switch which then turns green ) ^^
A little bit confusing, you have to activate like above and start the jail
Thanks for the feedback.
