ThermoDust 12 Posted July 11, 2017 Posted July 11, 2017 I like having the up next dialog but I would suggest giving a toggle option to make it so I can have it display the small up next dialog instead of the large one by default.
CBers 7554 Posted July 11, 2017 Posted July 11, 2017 Android TV? Which device? There is an option in the settings which shows it big or small. If you DISABLE the "Show Next Up Preview" option, you should only get the small dialog box.
ebr 16337 Posted July 12, 2017 Posted July 12, 2017 If you DISABLE the "Show Next Up Preview" option, you should only get the small dialog box. No, you should get neither...
CBers 7554 Posted July 12, 2017 Posted July 12, 2017 No, you should get neither... What is it you need disable/enable to just get the small dialog?
ebr 16337 Posted July 12, 2017 Posted July 12, 2017 What is it you need disable/enable to just get the small dialog? I don't believe it is possible right now which is why he is asking for it .
CBers 7554 Posted July 12, 2017 Posted July 12, 2017 I thought at one point in the app there was? If you enabled the Queue Subsequent Episodes option you got the big description, but then you added an option so that you'd only get the small dialog without the full description. What was this: v1.33 - Add option for "up next" display
ebr 16337 Posted July 13, 2017 Posted July 13, 2017 What was this: v1.33 - Add option for "up next" display That is the option of whether to show it or not. There is no option for large vs. small.
CBers 7554 Posted July 13, 2017 Posted July 13, 2017 That is the option of whether to show it or not. There is no option for large vs. small. I could have sworn someone requested it and you added something. I must be going mad then
