fkp 4 Posted July 11, 2017 Posted July 11, 2017 (edited) Hi, I'm trying to use HW Transcode without success and I need help. I'm using Debian 8 with emby server 3.2.25. I have a kernel 4.4 patched for QSV, installation is OK tests OK I have compiled ffmpeg with QSV support, tests OK My issue is when I select Intel Quick Sync or VAAPI, I have no video playback. the reason is quite simple, ffmpeg can not open /dev/dri/* as emby user the command extracted from emby's log : /home/ffmpeg/3.2.4/ffmpeg -c:v h264_qsv -i file:"/video/movie.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -preset 7 -look_ahead 0 -b:v 4616001 -maxrate 4616001 -bufsize 9232002 -profile:v high -level 4.1 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,3840)/2)*2:trunc(ow/dar/2)*2" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 6 -ab 384000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby-server/transcoding-temp/5c0682de230cb5847b5a3c37c2a54f83.m3u8" -y "/var/lib/emby-server/transcoding-temp/5c0682de230cb5847b5a3c37c2a54f83%d.ts" gives : ...... libva info: VA-API version 0.99.0libva info: va_getDriverName() returns 0libva info: User requested driver 'iHD 'libva info: Trying to open /opt/intel/mediasdk/lib64 /iHD _drv_video.solibva info: va_openDriver() returns -1[h264_qsv @ 0x2db02e0] mfx init: /dev/dri/renderD128 vaInitialize failed[h264_qsv @ 0x2db02e0] mfx init: /dev/dri/renderD129 fd open failed[h264_qsv @ 0x2db02e0] mfx init: /dev/dri/renderD130 fd open failed if I cut/paste the same command and run it as root it works libva info: VA-API version 0.99.0libva info: va_getDriverName() returns 0libva info: User requested driver 'iHD'libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.solibva info: Found init function __vaDriverInit_0_32libva info: va_openDriver() returns 0Output #0, segment, to '/var/lib/emby-server/transcoding-temp/5c0682de230cb5847b5a3c37c2a54f83%d.ts': Metadata: encoder : Lavf57.56.101 Stream #0:0: Video: h264 (h264_qsv), nv12, 1920x1080 [sAR 1:1 DAR 16:9], q=2-31, 4616 kb/s, 25 fps, 90k tbn, 25 tbc Metadata: encoder : Lavc57.64.101 h264_qsv Side data: cpb: bitrate max/min/avg: 4616001/0/4616001 buffer size: 9232002 vbv_delay: -1 Stream #0:1: Audio: aac (LC), 48000 Hz, 5.1, fltp (16 bit), 384 kb/s Metadata: encoder : Lavc57.64.101 aacStream mapping: Stream #0:0 -> #0:0 (h264 (h264_qsv) -> h264 (h264_qsv)) Stream #0:1 -> #0:1 (dts (dca) -> aac (native))libva info: VA-API version 0.99.0libva info: va_getDriverName() returns 0libva info: User requested driver 'iHD'libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.solibva info: Found init function __vaDriverInit_0_32libva info: va_openDriver() returns 0Input stream #0:0 frame changed from size:1920x1080 fmt:yuv420p to size:1920x1080 fmt:nv12frame= 904 fps=130 q=-0.0 Lsize=N/A time=00:00:36.54 bitrate=N/A speed=5.25xvideo:20376kB audio:1247kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown I have the same issue with vainfo ( gives information with root and none with non root user ). So I understand my problem is not linked to emby but perhaps someone here has found a solution. and : * I don't want to run emby as root * My server has no display ( no X running ) * emby user is in the video group # ls -l /dev/dritotal 0crw-rw-rw- 1 root video 226, 0 juil. 10 17:51 card0crw-rw-rw- 1 root video 226, 64 juil. 10 17:51 controlD64crw-rw-rw- 1 root video 226, 128 juil. 10 17:51 renderD128 Thanks ! Edited July 11, 2017 by fkp
Luke 42246 Posted July 11, 2017 Posted July 11, 2017 Sounds like the emby service user does not have permission for this, no?
dcrdev 255 Posted July 11, 2017 Posted July 11, 2017 ^ Yes that would look to be the case, although the OP said that the emby user is part of the video group. According to the above the rendering device is both owned by the video group and has the requisite permission to access it. Did you restart the emby service after adding the emby user to the group?
mastrmind11 722 Posted July 11, 2017 Posted July 11, 2017 According to Google there was also an ffmpeg bug a year or so ago that output this error which has supposedly been fixed in later versions. What version of ffmpeg are you compiling?
hooray4me 52 Posted July 11, 2017 Posted July 11, 2017 Try installing the ffmpeg version from ppa:jonathonf/ffmpeg-3
fkp 4 Posted July 12, 2017 Author Posted July 12, 2017 (edited) Sounds like the emby service user does not have permission for this, no? sure :-) ^ Yes that would look to be the case, although the OP said that the emby user is part of the video group. According to the above the rendering device is both owned by the video group and has the requisite permission to access it. Did you restart the emby service after adding the emby user to the group? yes, I have this problem for months now :-( According to Google there was also an ffmpeg bug a year or so ago that output this error which has supposedly been fixed in later versions. What version of ffmpeg are you compiling? 3.2.4 I will try to update my version. Try installing the ffmpeg version from ppa:jonathonf/ffmpeg-3 installation of this package does not work on my system ( no jessie amd64 version ?? ), but I will retry today. Thank you all for your support. Edited July 12, 2017 by fkp
Guest plexman Posted July 12, 2017 Posted July 12, 2017 If still doesn't work, give VAAPI a try. You'll avoid patched kernels and you'll get an easier configuration. Check this post: https://emby.media/community/index.php?/topic/31174-hardware-encoding-on-ubuntu-server/?p=369730
fkp 4 Posted July 15, 2017 Author Posted July 15, 2017 (edited) Moved to debian 9 and tried VAAPI, still the same kind of issue vainfo PuTTY X11 proxy: unable to connect to forwarded X server: Network error: Connection refused error: can't connect to X server! libva info: VA-API version 0.99.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.99 (libva 1.7.3) vainfo: Driver version: 16.4.4.47109-ubit vainfo: Supported profile and entrypoints VAProfileH264Baseline : VAEntrypointEncSlice VAProfileH264Baseline : VAEntrypointEncSliceLP VAProfileH264Baseline : <unknown entrypoint> VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileH264ConstrainedBaseline: <unknown entrypoint> VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264Main : <unknown entrypoint> VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : VAEntrypointEncSliceLP VAProfileH264High : <unknown entrypoint> VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : <unknown entrypoint> VAProfileHEVCMain : VAEntrypointEncSlice VAProfileVP9Profile0 : VAEntrypointEncSlice VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile0 : <unknown entrypoint> <unknown profile> : VAEntrypointVideoProc VAProfileNone : VAEntrypointVideoProc VAProfileNone : <unknown entrypoint> /home/ffmpeg/ffmpeg-git-20170118-64bit-static/ffmpeg -hwaccel vaapi -hwaccel_output_format vaapi -vaapi_device /dev/dri/renderD128 -i file:"/video/movie.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_vaapi -b:v 3616000 -maxrate 3616000 -bufsize 7232000 -level 41 -force_key_frames "expr:gte(t,n_forced*3)" -vf "format=nv12|vaapi,hwupload" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 6 -ab 384000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby-server/transcoding-temp/a3edc1669861b141cc2b8f648ccffd5d.m3u8" -y "/var/lib/emby-server/transcoding-temp/a3edc1669861b141cc2b8f648ccffd5d%d.ts"ffmpeg version N-83152-gf7e9275f83-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2017 the FFmpeg developers built with gcc 5.4.1 (Debian 5.4.1-4) 20161202 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc-5 --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gray --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libzimg libavutil 55. 43.100 / 55. 43.100 libavcodec 57. 74.100 / 57. 74.100 libavformat 57. 62.100 / 57. 62.100 libavdevice 57. 2.100 / 57. 2.100 libavfilter 6. 69.100 / 6. 69.100 libswscale 4. 3.101 / 4. 3.101 libswresample 2. 4.100 / 2. 4.100 libpostproc 54. 2.100 / 54. 2.100[AVHWDeviceContext @ 0x5000440] No VA display found for device: /dev/dri/renderD128.[vaapi @ 0x30f21e0] Failed to create a VAAPI device Edited July 15, 2017 by fkp
mastrmind11 722 Posted July 15, 2017 Posted July 15, 2017 Looks like VAAPI is correctly installed. What is the output of ls -al /dev/dri ? Perhaps you're just selecting an invalid dri. Try a different one.
fkp 4 Posted July 15, 2017 Author Posted July 15, 2017 Seems normal : ls -l /dev/dritotal 0crw-rw---- 1 root video 226, 0 juil. 15 09:12 card0crw-rw---- 1 root video 226, 64 juil. 15 09:12 controlD64crw-rw---- 1 root video 226, 128 juil. 15 09:12 renderD128 emby is part of group video.
Guest plexman Posted July 15, 2017 Posted July 15, 2017 What is your hardware? In my case with i5-6600 I get: libva info: VA-API version 0.39.4 vainfo: Driver version: Intel i965 driver for Intel® Skylake - 1.7.1 Enviado desde mi Aquaris E5 mediante Tapatalk
mastrmind11 722 Posted July 15, 2017 Posted July 15, 2017 I can confirm it's working on Haswell as well. libva info: VA-API version 0.39.4 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_0_39 libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.39 (libva 1.7.3) vainfo: Driver version: Intel i965 driver for Intel® Haswell Server - 1.7.0 1
fkp 4 Posted July 15, 2017 Author Posted July 15, 2017 Core i3 4170 (Haswell) not as recent as yours but should work.
Guest plexman Posted July 15, 2017 Posted July 15, 2017 (edited) Well my last suggestion is to try it under ubuntu 16.04, maybe as ubuntu includes more edgy software than debian it will work. Edit: I understand that it is not an easy solution, but I can't give you more help as it's difficult to know how is your system installed and all your system configuration. Plus, I don't have experience with Debian and VAAPI Enviado desde mi Aquaris E5 mediante Tapatalk Edited July 15, 2017 by plexman
sualfred 677 Posted July 16, 2017 Posted July 16, 2017 (edited) johnvansickle version has no VAAPI support. I've uploaded my compiled static libraries with enabled VAAPI support. There is also a .deb package for installation via dpkg.https://1drv.ms/f/s!Aj8g8aA7CEOwgfEQ0ykOaAfdomWc9Q Build in the mid of June and based on the GitHub snapshot with this configuration: configuration: --prefix=/root/sffmpeg/build --datadir=/root/sffmpeg/build/etc --disable-shared --enable-static --enable-gpl --enable-version3 --enable-nonfree --disable-doc --disable-debug --disable-ffplay --disable-ffserver --disable-outdevs --enable-runtime-cpudetect --extra-cflags='-I/root/sffmpeg/build/include --static' --extra-ldflags=-L/root/sffmpeg/build/lib --extra-libs='-lstdc++ -lexpat -ldl' --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfdk-aac --enable-libmp3lame --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libx265 --enable-libxvid --enable-libvpx --enable-libopus --enable-librtmp --enable-libfreetype --enable-libass --enable-vaapi Edited July 16, 2017 by sualfred 1
fkp 4 Posted July 16, 2017 Author Posted July 16, 2017 Not the same error message, but same result with your version of ffmpeg BUT with your version, I've seen a different error message (libva info: Trying to open /usr/lib64/dri/i965_drv_video.so) so even after updating from Jessie to stretch, my old libs created during my QSV tries were still here in /usr/lib64 and used by the system prior the "system" ones. removed this directory and now it works , tested with intel_gpu_top I have to clean up a little bit my system Thank You Sualfred and all of you. ffmpeg -hwaccel vaapi -hwaccel_output_format vaapi -vaapi_device /dev/dri/renderD128 -i file:"/video/movie.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_vaapi -b:v 3616000 -maxrate 3616000 -bufsize 7232000 -level 41 -force_key_frames "expr:gte(t,n_forced*3)" -vf "format=nv12|vaapi,hwupload" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 6 -ab 384000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby-server/transcoding-temp/9bb79820349de4fe1669690d5575f372.m3u8" -y "/var/lib/emby-server/transcoding-temp/9bb79820349de4fe1669690d5575f372%d.ts"ffmpeg version N-86486-g752dd19 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 4.9.2 (Debian 4.9.2-10) configuration: --prefix=/root/sffmpeg/build --datadir=/root/sffmpeg/build/etc --disable-shared --enable-static --enable-gpl --enable-version3 --enable-nonfree --disable-doc --disable-debug --disable-ffplay --disable-ffserver --disable-outdevs --enable-runtime-cpudetect --extra-cflags='-I/root/sffmpeg/build/include --static' --extra-ldflags=-L/root/sffmpeg/build/lib --extra-libs='-lstdc++ -lexpat -ldl' --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfdk-aac --enable-libmp3lame --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libx265 --enable-libxvid --enable-libvpx --enable-libopus --enable-librtmp --enable-libfreetype --enable-libass --enable-vaapi libavutil 55. 66.100 / 55. 66.100 libavcodec 57. 99.100 / 57. 99.100 libavformat 57. 73.100 / 57. 73.100 libavdevice 57. 7.100 / 57. 7.100 libavfilter 6. 92.100 / 6. 92.100 libswscale 4. 7.101 / 4. 7.101 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100libva info: VA-API version 0.99.0libva info: va_getDriverName() returns 0libva info: Trying to open /usr/lib64/dri/i965_drv_video.solibva info: va_openDriver() returns -1[AVHWDeviceContext @ 0x3789360] Failed to initialise VAAPI connection: -1 (unknown libva error).Device creation failed: -5.Failed to set value '/dev/dri/renderD128' for option 'vaapi_device': Input/output errorError parsing global options: Input/output error
sualfred 677 Posted July 16, 2017 Posted July 16, 2017 libva info: User requested driver 'iHD'libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so Haven't noticed that the QSV driver was still loaded as default, sorry. But nevermind.. glad that I could help. Btw: If you are facing artefacts -> add the unstable repo of Debian (SID). There is the upcoming 1.8.3 i965-va-driver available. It has a high quality improvment included. Don't forget you have to update vainfo aswell.
fkp 4 Posted July 17, 2017 Author Posted July 17, 2017 (edited) Btw: If you are facing artefacts -> add the unstable repo of Debian (SID). There is the upcoming 1.8.3 i965-va-driver available. It has a high quality improvment included. Don't forget you have to update vainfo aswell. Thanks for the tip, I've done this update, difficult to see the difference, software transcoding remains better than vaapi. Edited July 17, 2017 by fkp
Guest plexman Posted July 18, 2017 Posted July 18, 2017 [Out of thread] @@fkp the intel vaapi driver came by default with Debian 9 or you had to install something? Because I'm considering jumping from Ubuntu 16.04 to Debian 9 to try it.
fkp 4 Posted July 18, 2017 Author Posted July 18, 2017 Well, as I have upgraded from Debian 8 to 9, and as it was already installed, I had nothing to do. I don't know if you install it from scratch, it will be installed, anyway it is very easy to install ( 3 packages ...)
alfons27 0 Posted December 17, 2018 Posted December 17, 2018 I was in a similar situation as as @@fkp above. My errors looked like this: [AVHWDeviceContext @ 0x55a2e01f6780] Failed to initialise VAAPI connection: -1 (unknown libva error). Device creation failed: -5. Failed to set value '/dev/dri/renderD128' for option 'vaapi_device': Input/output error Error parsing global options: Input/output error Apparently emby did not have proper access to the hardware resources (because hardware acceleration worked as a regular user. It turned out I could mitigate this issue by adding LIBVA_DRIVERS_PATH=/usr/lib/dri LIBVA_DRIVER_NAME=iHD to the file /etc/conf.d/emby-server Maybe this is of help to someone. PS: I'm using emby Version 3.5.3.0, running on an Arch Linux machine (Kernel 4.19.8) with Intel Celeron CPU G3930 (w/ integrated Intel HD Graphics 610, Kaby Lake)
