bat19514 0 Posted July 10, 2017 Posted July 10, 2017 I have signed up but it not letting me go any further when I press the blue box with select sever on top can someone help Sent from my iPad using Tapatalk
chef 3811 Posted July 11, 2017 Posted July 11, 2017 (edited) Hello bat19514 Does your server show up in the selection box? Have you got the emby server running on your network? Have you forwarded the ports 8096 on your router? Edited July 11, 2017 by chef
Luke 42202 Posted July 11, 2017 Posted July 11, 2017 If you don't understand these questions, then let's start here. Have you installed your own Emby Server? Please let us know. Thanks !
Guest asrequested Posted July 11, 2017 Posted July 11, 2017 It sounds like you're clicking the select server label. It isn't a button. If there were a server in your network, it would be a box beneath the label.
bat19514 0 Posted July 11, 2017 Author Posted July 11, 2017 Yes I have installed my own Emby server Sent from my iPad using Tapatalk
Luke 42202 Posted July 11, 2017 Posted July 11, 2017 Have you setup Emby Connect? Check out our wiki on that: https://github.com/MediaBrowser/Wiki/wiki/Emby%20Connect Scroll down to the section "Guide for Administrators". Let us know if this helps. Thanks !
bat19514 0 Posted July 12, 2017 Author Posted July 12, 2017 Carnt find Guide for Administrator which part on the lists luke Sent from my iPad using Tapatalk
Luke 42202 Posted July 13, 2017 Posted July 13, 2017 Carnt find Guide for Administrator which part on the lists luke Sent from my iPad using Tapatalk Hi, just click the link in my post above and then scroll down a little, about halfway down the page. Let me know if this helps. Thanks !
