Swynol 375 Posted July 10, 2017 Posted July 10, 2017 Wondering what the possibility is of having a light weight client which runs in the task bar which has the option to output sound to a specified sound device. and be able to run multiple instances? at the moment i use a software airplay 'speaker' which i can specify which sound card i want to output to. I run 3 instances i.e. kitchen, living room, upstairs. it would be great to be able to send music to these rooms using emby. even better with amazon echo integration with emby
