henryford 11 Posted July 10, 2017 Posted July 10, 2017 Hi, I have disabled everything in regards to UPNP/DLNA, but emby still listens on port 1900. How do I disable SSDP completely so that nothing is listening in on 1900? Thanks in advance,
Luke 42239 Posted July 10, 2017 Posted July 10, 2017 Hi, I believe currently the low level device discovery services will remain active. It's something we can look at revising for a future update. thanks !
henryford 11 Posted July 10, 2017 Author Posted July 10, 2017 Ah, alright! Found this issue and the attached fix (https://github.com/MediaBrowser/Emby/issues/1578) which suggested to me that my actions should've stopped them from running, but that might have been misleading. Thanks for looking into it, until then I'll block the ports in the firewall :-)
