pir8radio 1313 Posted July 10, 2017 Posted July 10, 2017 Any reason why this M3U from NPVR wont work in emby? Because its not.... #EXTM3U #EXTINF:0, 1 - VOD Channel 1 http://10.0.1.17:8066/live?channel=1 #EXTINF:0, 2 - WBBM http://10.0.1.17:8066/live?channel=2 #EXTINF:0, 3 - ION Television (WCPX) http://10.0.1.17:8066/live?channel=3 #EXTINF:0, 4 - Comcast Network 100 http://10.0.1.17:8066/live?channel=4 #EXTINF:0, 5 - WMAQ http://10.0.1.17:8066/live?channel=5 #EXTINF:0, 6 - WFLD http://10.0.1.17:8066/live?channel=6 #EXTINF:0, 7 - WLS http://10.0.1.17:8066/live?channel=7 #EXTINF:0, 8 - WPWR http://10.0.1.17:8066/live?channel=8 #EXTINF:0, 9 - WGN (Local) http://10.0.1.17:8066/live?channel=9 #EXTINF:0, 11 - WTTW http://10.0.1.17:8066/live?channel=11 #EXTINF:0, 12 - WSNS http://10.0.1.17:8066/live?channel=12 #EXTINF:0, 13 - WJYS http://10.0.1.17:8066/live?channel=13 #EXTINF:0, 14 - WGBO http://10.0.1.17:8066/live?channel=14 #EXTINF:0, 15 - WXFT http://10.0.1.17:8066/live?channel=15 #EXTINF:0, 17 - WYIN http://10.0.1.17:8066/live?channel=17 #EXTINF:0, 19 - WCIU http://10.0.1.17:8066/live?channel=19 #EXTINF:0, 20 - Home Shopping Network http://10.0.1.17:8066/live?channel=20 #EXTINF:0, 21 - QVC Network http://10.0.1.17:8066/live?channel=21
Luke 42243 Posted July 10, 2017 Posted July 10, 2017 If you recall from how to report a problem, some key information is missing here that is preventing us from being able to help you. Describe the problem in your own words, including what you're trying to accomplish, and where you're getting stuck. Please mention some specific examples. In your description, be very specific about the steps you took and what happened with the system. Describe it like you are talking to a blind person - because you are. We cannot see what you did or what happened so be as specific as possible. If you saw error messages, please tell us what they were. If the problem is difficult to explain, please include screenshots that demonstrate the issue. Please attach the server log from the time frame the activity occurred. See the section below titled Emby Server Logs. Please supply the full and complete log file, and avoid attempting to extract relevant sections. Everything is relevant to us. When you attach the log, please also discuss what actions you took, and what the results were. Thanks !
pir8radio 1313 Posted July 11, 2017 Author Posted July 11, 2017 (edited) If you recall from how to report a problem, some key information is missing here that is preventing us from being able to help you. Describe the problem in your own words, including what you're trying to accomplish, and where you're getting stuck. Please mention some specific examples. In your description, be very specific about the steps you took and what happened with the system. Describe it like you are talking to a blind person - because you are. We cannot see what you did or what happened so be as specific as possible. If you saw error messages, please tell us what they were. If the problem is difficult to explain, please include screenshots that demonstrate the issue. Please attach the server log from the time frame the activity occurred. See the section below titled Emby Server Logs. Please supply the full and complete log file, and avoid attempting to extract relevant sections. Everything is relevant to us. When you attach the log, please also discuss what actions you took, and what the results were. Thanks ! I will gather the info. But my question was more, is there any reason why the m3u in post #1 wouldn't work with emby? Then I can trouble shoot on my own.. Edited July 11, 2017 by pir8radio
Jdiesel 1435 Posted July 11, 2017 Posted July 11, 2017 My guess is that is because the link doesn't end with a filename and extension like example.m3u or example.ts
pir8radio 1313 Posted July 11, 2017 Author Posted July 11, 2017 My guess is that is because the link doesn't end with a filename and extension like example.m3u or example.ts Yea that's kind of what I was thinking... I just wanted to make sure that the m3u format that NPVR spits out will work with emby.... Ill try saving the m3u on my webserver and getting at it like that.... Thx guys.
