parsaria 4 Posted July 9, 2017 Posted July 9, 2017 Does any one have a clue why a initial sync is not performed to Trakt.TV it does not give me an error. Collection is exported to Trakt fine btw, but the watch status is the problem here. But if you see movie now it updates the watch status as i noticed. in the log it only says: 2017-07-09 16:39:08.4527 Debug Trakt: TraktResponse Added Movies: 0 2017-07-09 16:39:08.4527 Debug Trakt: TraktResponse Added Shows: 0 log.txt
Luke 42253 Posted July 9, 2017 Posted July 9, 2017 You're trying to send watch status to trakt or receive?
paulsalter 84 Posted July 9, 2017 Posted July 9, 2017 No expert on these logs, but just under the bit you quoted it is saying it synced the watch state of 250 movies 10 Cloverfield lane is the first on 2016-06-21 Is this movie not flagged as watched on Trakt?
parsaria 4 Posted July 9, 2017 Author Posted July 9, 2017 Na, i am just wondering that my self also, there is no indication why it should not sync, but no historical watch statuses are synced.
parsaria 4 Posted July 9, 2017 Author Posted July 9, 2017 i think i don't understand what you are pointing at , i just started using trakt and wanted to import my watch statuses into trakt.....
Luke 42253 Posted July 9, 2017 Posted July 9, 2017 Ok, I am not a trakt user myself but I am just guessing that they would probably have that kind of history in your trakt account on the website. I could be wrong though.
parsaria 4 Posted July 9, 2017 Author Posted July 9, 2017 Ist't the plug-in suppose to sync the watched status from emby into your trakt account, or am i just being dumb here?? And if that is the case is there anything in the log that could give any clue why that is not happening?
parsaria 4 Posted July 10, 2017 Author Posted July 10, 2017 To be honest I don't know for sure, but i also don't know why that is relevant because like i said the collection are exported fine i see every tv-show and movies in my Trakt.tv bu there is no watch status at all. I just was looking the trakt.tv API manual. and saw the following. in the example of trakt.tv API manual "watched_at": "2014-09-01T09:10:11.000Z" but in my log every where i see "watched_at":"2017-05-23T23:32:41Z" Could it be that formating on a synology nas is different in mono??
Angelblue05 4132 Posted July 10, 2017 Posted July 10, 2017 Can you share your trakt plugin settings? Thanks.
parsaria 4 Posted July 10, 2017 Author Posted July 10, 2017 <?xml version="1.0"?> <PluginConfiguration xmlns:xsd="http://www.w3.org/2001/XMLSchema"xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <TraktUsers> <TraktUser> <UserName>username</UserName> <Password>*******</Password> <LinkedMbUserId>*******</LinkedMbUserId> <UsesAdvancedRating>false</UsesAdvancedRating> <UserToken>******</UserToken> <SkipUnwatchedImportFromTrakt>true</SkipUnwatchedImportFromTrakt> <PostWatchedHistory>true</PostWatchedHistory> <ExtraLogging>true</ExtraLogging> <ExportMediaInfo>false</ExportMediaInfo> <LocationsExcluded> <string>/volume2/video</string> <string>/volume2/music</string> <string>/volume2/photos</string> </LocationsExcluded> </TraktUser> </TraktUsers> </PluginConfiguration>
Angelblue05 4132 Posted July 10, 2017 Posted July 10, 2017 I use trakt, so I'll give it a shot and let you know if I encounter the same issue.
parsaria 4 Posted July 10, 2017 Author Posted July 10, 2017 Cool thank's. I am very curios what the problem might be!! Mostly I handle this problems my self, but this time I had no clue.
Angelblue05 4132 Posted July 10, 2017 Posted July 10, 2017 (edited) I can't get it to work, but in my case it fails because it's trying to authenticate someone that has no trakt account set up and no information set up in the plugin... Something is broke, the sync library to trakt failed because of it. Looks like this line is causing the issue: https://github.com/MediaBrowser/trakt/blob/master/Trakt/ScheduledTasks/SyncLibraryTask.cs#L95 If there's no trakt user, then the task should not run for this particular user but it does and throws an error when trying to authenticate. https://pastebin.com/a6CJgexP Edited July 10, 2017 by Angelblue05
parsaria 4 Posted July 10, 2017 Author Posted July 10, 2017 I removed these line of-course! So right now i am confused, but i can change my password of trakt and give you the private message of the real settings, if that is what you want. <UserName>username</UserName> <Password>*******</Password> <LinkedMbUserId>*******</LinkedMbUserId> <UserToken>******</UserToken>
Angelblue05 4132 Posted July 10, 2017 Posted July 10, 2017 No, don't remove anything. I still haven't been able to reproduce your bug because I'm stuck with another bug. So I'll let you know once I'm at the point of testing your issue.
parsaria 4 Posted July 10, 2017 Author Posted July 10, 2017 (edited) Then i know what your problem is you need to remove extra settings in Trakt.xml of the extra users, had that problem myself also. Somehow the Trakt Plugin save messes with the users. Edited July 10, 2017 by parsaria 1
Angelblue05 4132 Posted July 10, 2017 Posted July 10, 2017 (edited) Oh! Ok, thanks. I will check it out. Edit: Yep you are right, now it works. I ran the schedule task and what I marked as watched manually was not reported to trakt. Hmm. Edited July 10, 2017 by Angelblue05
parsaria 4 Posted July 10, 2017 Author Posted July 10, 2017 Could it be this : in the example of trakt.tv API manual "watched_at": "2014-09-01T09:10:11.000Z" but in my log every where i see "watched_at":"2017-05-23T23:32:41Z"
Angelblue05 4132 Posted July 10, 2017 Posted July 10, 2017 Honestly, I don't think it is that, because when you just finish watching something, it also sends that same time format and it works then. I'm looking and will let you know if I find something. 1
parsaria 4 Posted July 10, 2017 Author Posted July 10, 2017 Indeed you are right when you finish watching it works. But i am glad the problem is reproducible so we can work on it. Thanks for the support. 1
Angelblue05 4132 Posted July 10, 2017 Posted July 10, 2017 (edited) I don't think there's anything wrong with the code. At least I could not find anything wrong. The response the server sends follows the docs. I tested the trakt api site and it won't to add the watched status, request was succesful but trakt does nothing (beautiful apiary wish we had something as sleek as that for emby, but I digress)... Might have to contact trakt directly. { "added": { "movies": 0, "episodes": 0 }, "not_found": { "movies": [], "shows": [], "seasons": [], "episodes": [], "people": [] } } @@Luke https://github.com/MediaBrowser/trakt/blob/master/Trakt/Helpers/UserHelpers.cs#L33 Please add the following. It seems if you hit save in the plugin config on an account that has no trakt account setup, it creates a failed entry in the xml which then causes auth errors which crashes the trakt schedule task to sync emby to trakt. else if (string.IsNullOrWhiteSpace(tUser.UserName) || string.IsNullOrWhiteSpace(tUser.Password)) { return false; } <TraktUser> <UserName /> ?? <Password /> ?? <LinkedMbUserId>72847ba4055b45c289de7a6d6e5a892a</LinkedMbUserId> <UsesAdvancedRating>false</UsesAdvancedRating> <SkipUnwatchedImportFromTrakt>true</SkipUnwatchedImportFromTrakt> <PostWatchedHistory>true</PostWatchedHistory> <ExtraLogging>false</ExtraLogging> <ExportMediaInfo>false</ExportMediaInfo> <LocationsExcluded /> </TraktUser> Edited July 10, 2017 by Angelblue05
parsaria 4 Posted July 10, 2017 Author Posted July 10, 2017 Maybe it is also good to add a XML Element in the feature called "Disabled" so you can select this in the UI with a checkbox. <TraktUser> <UserName /> ?? <Password /> ?? <LinkedMbUserId>72847ba4055b45c289de7a6d6e5a892a</LinkedMbUserId> <UsesAdvancedRating>false</UsesAdvancedRating> <SkipUnwatchedImportFromTrakt>true</SkipUnwatchedImportFromTrakt> <PostWatchedHistory>true</PostWatchedHistory> <ExtraLogging>false</ExtraLogging> <ExportMediaInfo>false</ExportMediaInfo> <LocationsExcluded /> <Disabled>false</Disabled> </TraktUser>
