ensign.fodder 1 Posted July 9, 2017 Posted July 9, 2017 Non-premier user (waiting on next sale) with Win 2012R2 server hosting Emby. Since Roku beta channel went release I have had a number of issues. I have the older Roku 2XS and one Roku 3 (now called Roku 2) and all are working less well then before. Most common issue is the Roku says it is playing but the server shows no transcoding activity. Same user logs into the web site and accesses same item and it plays in the browser and shows transcoding activity on the server. The server dashboard shows the show being played both times but you can see the one that is not transcoding since it shows no show image. There are other issues like subtitle activation causes entire stream to restart/stall but this is another "failure to transcode" issue. Let me know what information I can provide to help with issue resolution. Thanks.
Luke 42242 Posted July 9, 2017 Posted July 9, 2017 Hi there, we're sorry to hear about this. Can you please discuss an example, and then attach the information requested in how to report a media playback issue? thanks !
ensign.fodder 1 Posted July 10, 2017 Author Posted July 10, 2017 So there is no ffmpeg remux log but here is the relevant part of the server log. 2017-07-08 20:52:33.6561 Info App: User policy for Person. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2017-07-08 20:52:33.6767 Info App: Profile: Roku SG, Path: E:\TV\Show\Episode.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2017-07-08 20:52:33.6897 Info App: Profile: Roku SG, No direct play profiles found for Path: E:\TV\Show\Episode.mkv 2017-07-08 20:52:33.7097 Info App: RemoteClientBitrateLimit: 5000000, RemoteIp: 10.10.0.31, IsInLocalNetwork: True 2017-07-08 20:52:33.7097 Info App: Profile: Roku SG, Path: E:\TV\Show\Episode, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2017-07-08 20:52:33.7097 Info App: Profile: Roku SG, No direct play profiles found for Path: E:\TV\Show\Episode.mkv 2017-07-08 20:52:33.7097 Info App: RemoteClientBitrateLimit: 5000000, RemoteIp: 10.10.0.31, IsInLocalNetwork: True 2017-07-08 20:52:33.7097 Info App: Profile: Roku SG, Path: E:\TV\Show\Episode.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2017-07-08 20:52:33.7097 Info App: Profile: Roku SG, No direct play profiles found for Path: E:\TV\Show\Episode.mkv 2017-07-08 20:52:33.7407 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 187ms. http://10.10.0.4:8096/emby/Items/caa4b0035f224f2f9542e62d3f7b85d1/PlaybackInfo?UserId=9544a5fe514cea76d51529448f457ebe&starttimeticks=00000000&maxstreamingbitrate=50196080 2017-07-08 20:52:40.1817 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Playback/BitrateTest?size=100000. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:40.1817 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 1ms. http://10.10.0.4:8096/emby/Playback/BitrateTest?size=100000 2017-07-08 20:52:40.4230 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Playback/BitrateTest?size=1000000. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:40.4230 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 16ms. http://10.10.0.4:8096/emby/Playback/BitrateTest?size=1000000 2017-07-08 20:52:40.7137 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Playback/BitrateTest?size=10000000. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:40.7457 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 32ms. http://10.10.0.4:8096/emby/Playback/BitrateTest?size=10000000 2017-07-08 20:53:42.5175 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration/encoding. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:53:42.5175 Info HttpServer: HTTP Response 200 to ::1. Time: 8ms. http://localhost:8096/emby/System/Configuration/encoding 2017-07-08 20:53:42.5315 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:53:42.5805 Info HttpServer: HTTP Response 200 to ::1. Time: 49ms. http://localhost:8096/emby/System/Info 2017-07-08 20:54:38.5568 Info HttpServer: HTTP GET http://10.10.0.4:8096/dlna/2079a4eac649448b8a525e7826bb0f48/description.xml. UserAgent: FDSSDP 2017-07-08 20:54:38.5568 Info Dlna: No matching device profile found. The default will need to be used. Cache-Control: no-cache Connection: Keep-Alive Pragma: no-cache Accept: text/xml, application/xml Accept-Encoding: peerdist User-Agent: FDSSDP X-P2P-PeerDist: Version=1.1 X-P2P-PeerDistEx: MinContentInformation=1.0, MaxContentInformation=2.0 Host: 10.10.0.4:8096
ensign.fodder 1 Posted July 10, 2017 Author Posted July 10, 2017 As a side note I have been running this for a while and my path to logs is different from the linked article. %appdata%\MediaBrowser-Server\logs instead of %appdata%\Emby-Server\logs
Luke 42242 Posted July 10, 2017 Posted July 10, 2017 can you please attach the complete emby server log? thanks !
ebr 16335 Posted July 10, 2017 Posted July 10, 2017 I'm a little unclear on what the actual issue is. You say "transcoding doesn't happen". Does that mean that the video doesn't play? What, exactly, happens on the Roku side?
ensign.fodder 1 Posted July 10, 2017 Author Posted July 10, 2017 (edited) @ ebr - On Roku side the "spinning wheel" starts and the expected next step would be the stream would start playing but it does not. From web client for same file, I see the transcoding spike CPU, the transcoded chunks in the the temp location, and it plays the file. Edited July 10, 2017 by ensign.fodder
ensign.fodder 1 Posted July 10, 2017 Author Posted July 10, 2017 (edited) @@Luke Moved below. Edited July 12, 2017 by ensign.fodder
ensign.fodder 1 Posted July 10, 2017 Author Posted July 10, 2017 No way to do file attachment? 2017-07-08 20:51:44.9442 Info Main: Emby Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application directory: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System 2017-07-08 20:51:45.8830 Info App: Application version: 3.2.24.0 2017-07-08 20:51:45.9840 Info App: Application configuration: {"EnableUPnP":false,"PublicPort":8096,"PublicHttpsPort":8920,"HttpServerPortNumber":8096,"HttpsPortNumber":8920,"EnableHttps":false,"EnableLocalizedGuids":true,"EnableNormalizedItemByNameIds":false,"IsPortAuthorized":true,"EnableCaseSensitiveItemIds":false,"DisableLiveTvChannelUserDataName":false,"MetadataPath":"","SeasonZeroDisplayName":"Specials","PreferredMetadataLanguage":"en","MetadataCountryCode":"US","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"LibraryMonitorDelay":60,"EnableDashboardResponseCaching":true,"DashboardSourcePath":"","ImageSavingConvention":"Compatible","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Movie","ImageOptions":[{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Art","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Backdrop","Limit":5,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":["Nfo","Emby Xml"],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":["TheMovieDb","The Open Movie Database"],"DisabledImageFetchers":[],"ImageFetcherOrder":["TheMovieDb","FanArt","The Open Movie Database","Screen Grabber"]},{"ItemType":"Series","ImageOptions":[{"Type":"Backdrop","Limit":2,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Disc","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Episode","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":["The Open Movie Database","TheMovieDb"],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicVideo","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Video","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]}],"EnableAutomaticRestart":true,"SkipDeserializationForBasicTypes":false,"SkipDeserializationForAudio":false,"ServerName":"","WanDdns":"quickpack-zkkqmdcdmn.dynamic-m.com","UICulture":"en-us","SaveMetadataHidden":false,"ContentTypes":[],"RemoteClientBitrateLimit":5000000,"SharingExpirationDays":30,"SchemaVersion":109,"EnableAnonymousUsageReporting":true,"EnableStandaloneMusicKeys":false,"EnableFolderView":false,"EnableGroupingIntoCollections":false,"DisplaySpecialsWithinSeasons":true,"DisplayCollectionsView":false,"LocalNetworkAddresses":[],"CodecsUsed":["libmp3lame","copy","libx264"],"EnableChannelView":false,"EnableExternalContentInSuggestions":true,"ImageExtractionTimeoutMs":10000,"PathSubstitutions":[],"EnableSimpleArtistDetection":true,"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"LogFileRetentionDays":3,"RunAtStartup":true,"IsStartupWizardCompleted":true,"CachePath":""} 2017-07-08 20:51:45.9950 Info App: Loading MediaBrowser.Api, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading MediaBrowser.WebDashboard, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading MediaBrowser.Model, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading MediaBrowser.Common, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading MediaBrowser.Controller, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading MediaBrowser.Providers, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading Emby.Photos, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading Emby.Common.Implementations, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading Emby.Server.Implementations, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading MediaBrowser.MediaEncoding, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading MediaBrowser.LocalMetadata, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading MediaBrowser.XbmcMetadata, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading MediaBrowser.ServerApplication, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:45.9950 Info App: Loading Emby.Server.Core, Version=3.2.24.0, Culture=neutral, PublicKeyToken=null 2017-07-08 20:51:46.2370 Info SqliteUserRepository: Sqlite version: 3.19.2 2017-07-08 20:51:46.2370 Info SqliteUserRepository: Sqlite compiler options: COMPILER=msvc-1500,DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_SYNCHRONOUS=2,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_RTREE,SYSTEM_MALLOC,TEMP_STORE=1,THREADSAFE=1 2017-07-08 20:51:46.2720 Info SqliteUserRepository: Default journal_mode for C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\users.db is wal 2017-07-08 20:51:46.2720 Info SqliteUserRepository: PRAGMA synchronous=1 2017-07-08 20:51:46.2900 Info SqliteFileOrganizationRepository: Default journal_mode for C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\fileorganization.db is wal 2017-07-08 20:51:46.2900 Info SqliteFileOrganizationRepository: PRAGMA synchronous=1 2017-07-08 20:51:46.2900 Info AuthenticationRepository: Default journal_mode for C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\authentication.db is wal 2017-07-08 20:51:46.2900 Info AuthenticationRepository: PRAGMA synchronous=1 2017-07-08 20:51:46.4634 Info SharingRepository: Default journal_mode for C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\shares.db is wal 2017-07-08 20:51:46.4634 Info SharingRepository: PRAGMA synchronous=1 2017-07-08 20:51:46.4634 Info ActivityRepository: Default journal_mode for C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\activitylog.db is wal 2017-07-08 20:51:46.4634 Info ActivityRepository: PRAGMA synchronous=1 2017-07-08 20:51:46.4634 Info SqliteDisplayPreferencesRepository: Default journal_mode for C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\displaypreferences.db is wal 2017-07-08 20:51:46.4634 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 2017-07-08 20:51:46.4634 Info SqliteItemRepository: Default journal_mode for C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\library.db is wal 2017-07-08 20:51:46.4634 Info SqliteItemRepository: PRAGMA synchronous=1 2017-07-08 20:51:46.4831 Info SqliteNotificationsRepository: Default journal_mode for C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\notifications.db is wal 2017-07-08 20:51:46.4831 Info SqliteNotificationsRepository: PRAGMA synchronous=1 2017-07-08 20:51:46.8299 Info HttpServer: Calling ServiceStack AppHost.Init 2017-07-08 20:51:47.4487 Info ServerManager: Loading Http Server 2017-07-08 20:51:47.4487 Info HttpServer: Adding HttpListener prefix http://+:8096/ 2017-07-08 20:51:47.4487 Info HttpServer: Adding HttpListener prefix https://+:8920/ 2017-07-08 20:51:47.7253 Info Skia: SkiaSharp version: 1.58.0.0 2017-07-08 20:51:47.7663 Info TaskManager: Daily trigger for Start new log file set to fire at 7/9/2017 12:00:00 AM, which is 188.203894411667 minutes from now. 2017-07-08 20:51:47.7663 Info TaskManager: Daily trigger for Chapter image extraction set to fire at 7/9/2017 2:00:00 AM, which is 308.203894411667 minutes from now. 2017-07-08 20:51:47.8288 Info MediaEncoder: FFMpeg: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20160410\ffmpeg.exe 2017-07-08 20:51:47.8288 Info MediaEncoder: FFProbe: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20160410\ffprobe.exe 2017-07-08 20:51:47.8288 Info MediaEncoder: Validating media encoder at C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20160410\ffmpeg.exe 2017-07-08 20:51:47.8288 Info MediaEncoder: Running C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20160410\ffmpeg.exe -decoders 2017-07-08 20:51:47.9071 Info MediaEncoder: Decoder available: mpeg2video 2017-07-08 20:51:47.9071 Info MediaEncoder: Decoder available: h264_qsv 2017-07-08 20:51:47.9071 Info MediaEncoder: Decoder available: hevc_qsv 2017-07-08 20:51:47.9071 Info MediaEncoder: Decoder available: mpeg2_qsv 2017-07-08 20:51:47.9071 Info MediaEncoder: Decoder available: vc1_qsv 2017-07-08 20:51:47.9071 Info MediaEncoder: Decoder available: ac3 2017-07-08 20:51:47.9071 Info MediaEncoder: Decoder available: aac 2017-07-08 20:51:47.9071 Info MediaEncoder: Decoder available: mp3 2017-07-08 20:51:47.9071 Info MediaEncoder: Decoder available: h264 2017-07-08 20:51:47.9071 Info MediaEncoder: Decoder available: hevc 2017-07-08 20:51:47.9071 Info MediaEncoder: Running C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20160410\ffmpeg.exe -encoders 2017-07-08 20:51:47.9714 Info MediaEncoder: Encoder available: libx264 2017-07-08 20:51:47.9714 Info MediaEncoder: Encoder available: libx265 2017-07-08 20:51:47.9714 Info MediaEncoder: Encoder available: mpeg4 2017-07-08 20:51:47.9714 Info MediaEncoder: Encoder available: msmpeg4 2017-07-08 20:51:47.9714 Info MediaEncoder: Encoder available: libvpx 2017-07-08 20:51:47.9714 Info MediaEncoder: Encoder available: libvpx-vp9 2017-07-08 20:51:47.9714 Info MediaEncoder: Encoder available: aac 2017-07-08 20:51:47.9870 Info MediaEncoder: Encoder available: libmp3lame 2017-07-08 20:51:47.9870 Info MediaEncoder: Encoder available: libopus 2017-07-08 20:51:47.9870 Info MediaEncoder: Encoder available: libvorbis 2017-07-08 20:51:47.9870 Info MediaEncoder: Encoder available: srt 2017-07-08 20:51:47.9870 Info MediaEncoder: Encoder available: h264_nvenc 2017-07-08 20:51:47.9870 Info MediaEncoder: Encoder available: hevc_nvenc 2017-07-08 20:51:47.9870 Info MediaEncoder: Encoder available: h264_qsv 2017-07-08 20:51:47.9870 Info MediaEncoder: Encoder available: hevc_qsv 2017-07-08 20:51:47.9870 Info MediaEncoder: Encoder validation complete 2017-07-08 20:51:47.9870 Info App: ServerId: 2079a4eac649448b8a525e7826bb0f48 2017-07-08 20:51:47.9870 Info App: Core startup complete 2017-07-08 20:51:47.9870 Info App: Post-init migrations complete 2017-07-08 20:51:48.0349 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2017-07-08 20:51:48.0349 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.0349 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint 2017-07-08 20:51:48.0349 Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.0349 Info App: Starting entry point Emby.Server.Implementations.TV.CleanMissingEpisodesEntryPoint 2017-07-08 20:51:48.0349 Info App: Entry point completed: Emby.Server.Implementations.TV.CleanMissingEpisodesEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.0349 Info App: Starting entry point Emby.Server.Implementations.Notifications.Notifications 2017-07-08 20:51:48.0349 Info App: Entry point completed: Emby.Server.Implementations.Notifications.Notifications. Duration: 0 seconds 2017-07-08 20:51:48.0349 Info App: Starting entry point Emby.Server.Implementations.Notifications.WebSocketNotifier 2017-07-08 20:51:48.0349 Info App: Entry point completed: Emby.Server.Implementations.Notifications.WebSocketNotifier. Duration: 0 seconds 2017-07-08 20:51:48.0349 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2017-07-08 20:51:48.0349 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.0349 Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint 2017-07-08 20:51:48.0349 Info App: Loading live tv data from C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\livetv\timers 2017-07-08 20:51:48.1826 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.1476845 seconds 2017-07-08 20:51:48.1826 Info App: Starting entry point Emby.Server.Implementations.FileOrganization.FileOrganizationNotifier 2017-07-08 20:51:48.1826 Info App: Entry point completed: Emby.Server.Implementations.FileOrganization.FileOrganizationNotifier. Duration: 0 seconds 2017-07-08 20:51:48.1826 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2017-07-08 20:51:48.1826 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.1826 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2017-07-08 20:51:48.1826 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0 seconds 2017-07-08 20:51:48.1826 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2017-07-08 20:51:48.1826 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0 seconds 2017-07-08 20:51:48.1826 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LoadRegistrations 2017-07-08 20:51:48.1826 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LoadRegistrations. Duration: 0 seconds 2017-07-08 20:51:48.1826 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier 2017-07-08 20:51:48.1826 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0 seconds 2017-07-08 20:51:48.1826 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RefreshUsersMetadata 2017-07-08 20:51:48.3405 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RefreshUsersMetadata. Duration: 0.1579431 seconds 2017-07-08 20:51:48.3405 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2017-07-08 20:51:48.3405 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0 seconds 2017-07-08 20:51:48.3405 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2017-07-08 20:51:48.3405 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0 seconds 2017-07-08 20:51:48.3405 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2017-07-08 20:51:48.3405 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0 seconds 2017-07-08 20:51:48.3405 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint 2017-07-08 20:51:48.3562 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0156192 seconds 2017-07-08 20:51:48.3562 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint 2017-07-08 20:51:48.3562 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.3562 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2017-07-08 20:51:48.3562 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0 seconds 2017-07-08 20:51:48.3562 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 2017-07-08 20:51:48.3562 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.3562 Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint 2017-07-08 20:51:48.3562 Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.3562 Info App: Starting entry point Emby.Dlna.DlnaProfileEntryPoint 2017-07-08 20:51:48.3562 Info App: Entry point completed: Emby.Dlna.DlnaProfileEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.3562 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2017-07-08 20:51:48.5660 Info HttpClient: HttpClientManager GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2017-07-08 20:51:48.5817 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.2254997 seconds 2017-07-08 20:51:48.5817 Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint 2017-07-08 20:51:48.5817 Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.5817 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2017-07-08 20:51:48.5817 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.5817 Info App: Starting entry point Emby.Security.PluginSecurityManager 2017-07-08 20:51:48.5817 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0 seconds 2017-07-08 20:51:48.5817 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2017-07-08 20:51:48.5817 Info App: Loading data from C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\connect.txt 2017-07-08 20:51:48.5973 Info App: Loading data from C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\wan.dat 2017-07-08 20:51:48.6129 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0312484 seconds 2017-07-08 20:51:48.6129 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2017-07-08 20:51:48.6129 Info App: Sqlite version: 3.19.2 2017-07-08 20:51:48.6129 Info App: Sqlite compiler options: COMPILER=msvc-1500,DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_SYNCHRONOUS=2,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_RTREE,SYSTEM_MALLOC,TEMP_STORE=1,THREADSAFE=1 2017-07-08 20:51:48.6129 Info App: Default journal_mode for C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\data\sync14.db is wal 2017-07-08 20:51:48.6129 Info App: PRAGMA synchronous=1 2017-07-08 20:51:48.6129 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.6129 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2017-07-08 20:51:48.6129 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0 seconds 2017-07-08 20:51:48.6129 Info App: Starting entry point Emby.Security.PluginSecurityManager 2017-07-08 20:51:48.6285 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0.0156265 seconds 2017-07-08 20:51:48.6285 Info App: Starting entry point Emby.Server.Core.IO.LibraryMonitorStartup 2017-07-08 20:51:48.6442 Info App: Entry point completed: Emby.Server.Core.IO.LibraryMonitorStartup. Duration: 0.015625 seconds 2017-07-08 20:51:48.6442 Info App: Starting entry point Emby.Server.Core.EntryPoints.ExternalPortForwarding 2017-07-08 20:51:48.6442 Info LibraryMonitor: Watching directory E:\TV 2017-07-08 20:51:48.6442 Info LibraryMonitor: Watching directory E:\Movies 2017-07-08 20:51:48.7314 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 10.10.0.4 2017-07-08 20:51:48.7314 Info App: Entry point completed: Emby.Server.Core.EntryPoints.ExternalPortForwarding. Duration: 0.087249 seconds 2017-07-08 20:51:48.7314 Info App: All entry points have started 2017-07-08 20:51:48.8408 Info HttpServer: HTTP GET http://10.10.0.4:8096/dlna/2079a4eac649448b8a525e7826bb0f48/description.xml. UserAgent: Android/5.1.1 UPnP/1.0 Cling/2.0 2017-07-08 20:51:48.8567 Info HttpClient: HttpClientManager POST: https://connect.emby.media/service/Servers?id=1a23f809b57de49a4b2d70d8e2fba5ed 2017-07-08 20:51:48.8567 Info Dlna: No matching device profile found. The default will need to be used. Host: 10.10.0.4:8096 Connection: Keep-Alive User-Agent: Android/5.1.1 UPnP/1.0 Cling/2.0 2017-07-08 20:51:48.8790 Info HttpServer: HTTP Response 200 to 10.10.0.166. Time: 37ms. http://10.10.0.4:8096/dlna/2079a4eac649448b8a525e7826bb0f48/description.xml 2017-07-08 20:51:48.9070 Info HttpServer: HTTP GET http://10.10.0.4:8096/dlna/2079a4eac649448b8a525e7826bb0f48/contentdirectory/contentdirectory.xml. UserAgent: Android/5.1.1 UPnP/1.0 Cling/2.0 2017-07-08 20:51:48.9070 Info HttpServer: HTTP Response 200 to 10.10.0.166. Time: 4ms. http://10.10.0.4:8096/dlna/2079a4eac649448b8a525e7826bb0f48/contentdirectory/contentdirectory.xml 2017-07-08 20:51:49.0255 Info HttpClient: HttpClientManager GET: https://connect.emby.media/service/ServerAuthorizations?serverId=1a23f809b57de49a4b2d70d8e2fba5ed 2017-07-08 20:51:49.1190 Info HttpServer: HTTP GET http://10.10.0.4:8096/dlna/2079a4eac649448b8a525e7826bb0f48/connectionmanager/connectionmanager.xml. UserAgent: Android/5.1.1 UPnP/1.0 Cling/2.0 2017-07-08 20:51:49.1347 Info HttpServer: HTTP Response 200 to 10.10.0.166. Time: 16ms. http://10.10.0.4:8096/dlna/2079a4eac649448b8a525e7826bb0f48/connectionmanager/connectionmanager.xml 2017-07-08 20:51:50.7699 Info TaskManager: StartupTrigger fired for task: Check for plugin updates 2017-07-08 20:51:50.7699 Info TaskManager: StartupTrigger fired for task: Check for application updates 2017-07-08 20:51:50.7699 Info TaskManager: Queueing task PluginUpdateTask 2017-07-08 20:51:50.7699 Info TaskManager: Queueing task SystemUpdateTask 2017-07-08 20:51:50.7699 Info TaskManager: Executing Check for plugin updates 2017-07-08 20:51:50.7699 Info TaskManager: Executing Check for application updates 2017-07-08 20:51:50.7919 Info InstallationManager: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\cache\serverpackages.json 2017-07-08 20:51:50.7919 Info HttpClient: Checking for cache file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\cache\httpclient\f70ca6622474da8168a3b6c06f651a16 2017-07-08 20:51:50.8629 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds 2017-07-08 20:51:50.8629 Info HttpClient: HttpClientManager.GetTempFileResponse url: https://www.mb3admin.com/admin/service/MB3Packages.json 2017-07-08 20:51:50.8779 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2017-07-08 20:51:50.8919 Info TaskManager: ExecuteQueuedTasks 2017-07-08 20:51:50.8919 Info TaskManager: ExecuteQueuedTasks 2017-07-08 20:51:54.0539 Info HttpClient: HttpClientManager POST: https://connect.emby.media/service/Servers?id=1a23f809b57de49a4b2d70d8e2fba5ed 2017-07-08 20:51:54.1059 Info HttpServer: HTTP GET http://localhost:8096/web/strings/en-us.json?v=1499561514101. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:54.1059 Info HttpServer: HTTP GET http://localhost:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1499561514101. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:54.1109 Info HttpResultFactory: Transmit file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\dashboard-ui\bower_components\emby-webcomponents\strings\en-us.json 2017-07-08 20:51:54.1109 Info HttpResultFactory: Transmit file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\dashboard-ui\strings\en-us.json 2017-07-08 20:51:54.1109 Info HttpServer: HTTP Response 200 to ::1. Time: 10ms. http://localhost:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1499561514101 2017-07-08 20:51:54.1109 Info HttpServer: HTTP Response 200 to ::1. Time: 13ms. http://localhost:8096/web/strings/en-us.json?v=1499561514101 2017-07-08 20:51:54.1889 Info HttpClient: HttpClientManager GET: https://connect.emby.media/service/ServerAuthorizations?serverId=1a23f809b57de49a4b2d70d8e2fba5ed 2017-07-08 20:51:54.2919 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/favicon.ico. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:54.2919 Info HttpResultFactory: Transmit file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\dashboard-ui\css\images\favicon.ico 2017-07-08 20:51:54.2919 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:8096/web/css/images/favicon.ico 2017-07-08 20:51:54.5909 Info HttpResultFactory: Transmit file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\dashboard-ui\bower_components\emby-webcomponents\fonts\material-icons\2fcryfnatjcs6g4u3t-y5zjzjt5fdej140u2djyc3my.woff2 2017-07-08 20:51:54.6849 Info HttpServer: HTTP GET http://localhost:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:54.7549 Info HttpServer: HTTP Response 200 to ::1. Time: 70ms. http://localhost:8096/emby/system/info/public 2017-07-08 20:51:54.7659 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:54.8049 Info App: App Activity: app: Emby Mobile, version: 3.1.11.0, deviceId: 26a51c7d17c13894c057c932bed1239e, deviceName: Chrome 51.0.2704.79 2017-07-08 20:51:55.2119 Info HttpServer: HTTP Response 200 to ::1. Time: 446ms. http://localhost:8096/emby/System/Info 2017-07-08 20:51:55.2119 Info HttpServer: HTTP GET http://localhost:8096/emby/users/f6c51e6fd330e59d16f4cc52886702e1. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.2789 Info HttpServer: HTTP Response 200 to ::1. Time: 60ms. http://localhost:8096/emby/users/f6c51e6fd330e59d16f4cc52886702e1 2017-07-08 20:51:55.2999 Info HttpServer: HTTP GET http://localhost:8096/emby/DisplayPreferences/usersettings?userId=f6c51e6fd330e59d16f4cc52886702e1&client=emby. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.3129 Info HttpServer: HTTP POST http://localhost:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.3129 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/f6c51e6fd330e59d16f4cc52886702e1. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.3129 Info HttpServer: WS ws://localhost:8096/embywebsocket?api_key=adce2efe203a4f439e9451a44f555eca&deviceId=26a51c7d17c13894c057c932bed1239e. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.3369 Info HttpServer: HTTP Response 200 to ::1. Time: 22ms. http://localhost:8096/emby/Users/f6c51e6fd330e59d16f4cc52886702e1 2017-07-08 20:51:55.3569 Info HttpServer: HTTP Response 204 to ::1. Time: 44ms. http://localhost:8096/emby/Sessions/Capabilities/Full 2017-07-08 20:51:55.4549 Info HttpServer: HTTP Response 200 to ::1. Time: 155ms. http://localhost:8096/emby/DisplayPreferences/usersettings?userId=f6c51e6fd330e59d16f4cc52886702e1&client=emby 2017-07-08 20:51:55.4869 Info HttpServer: HTTP GET http://localhost:8096/emby/Notifications/f6c51e6fd330e59d16f4cc52886702e1/Summary. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.4869 Info HttpServer: HTTP GET http://localhost:8096/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.4869 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.5009 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.5009 Info HttpServer: HTTP GET http://localhost:8096/emby/Plugins/SecurityInfo. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.5529 Info HttpServer: HTTP Response 200 to ::1. Time: 66ms. http://localhost:8096/emby/Notifications/f6c51e6fd330e59d16f4cc52886702e1/Summary 2017-07-08 20:51:55.5659 Info HttpResultFactory: Transmit file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\dashboard-ui\fonts\roboto\cwb0xya8bzo0ksthx0utua.woff2 2017-07-08 20:51:55.5659 Info HttpResultFactory: Transmit file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\dashboard-ui\fonts\roboto\rxzjdnzeo3r5zsexge8uuvtxra8tvwticgirnjhmvjw.woff2 2017-07-08 20:51:55.5659 Info HttpServer: HTTP GET http://localhost:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.6759 Info HttpServer: HTTP Response 200 to ::1. Time: 98ms. http://localhost:8096/emby/News/Product?StartIndex=0&Limit=4 2017-07-08 20:51:55.6759 Info HttpServer: HTTP Response 200 to ::1. Time: 178ms. http://localhost:8096/emby/ScheduledTasks 2017-07-08 20:51:55.6759 Info HttpServer: HTTP GET http://localhost:8096/emby/DisplayPreferences/dashboard?userId=f6c51e6fd330e59d16f4cc52886702e1&client=dashboard. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.6759 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/DisplayPreferences/dashboard?userId=f6c51e6fd330e59d16f4cc52886702e1&client=dashboard 2017-07-08 20:51:55.6989 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/logoblack.png. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.6989 Info HttpResultFactory: Transmit file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\dashboard-ui\css\images\logoblack.png 2017-07-08 20:51:55.6989 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/web/css/images/logoblack.png 2017-07-08 20:51:55.7279 Info HttpServer: HTTP Response 200 to ::1. Time: 227ms. http://localhost:8096/emby/System/Info 2017-07-08 20:51:55.7279 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2017-07-08T00%3A51%3A55.458Z. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.7719 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.7719 Info HttpClient: Checking for cache file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\cache\httpclient\f70ca6622474da8168a3b6c06f651a16 2017-07-08 20:51:55.7719 Info HttpClient: HttpClientManager POST: https://mb3admin.com/admin/service/registration/validate 2017-07-08 20:51:55.8059 Info HttpServer: HTTP Response 200 to ::1. Time: 318ms. http://localhost:8096/emby/Sessions 2017-07-08 20:51:55.8229 Info HttpServer: HTTP Response 200 to ::1. Time: 51ms. http://localhost:8096/emby/Packages/Updates?PackageType=System 2017-07-08 20:51:55.8229 Info HttpServer: HTTP Response 200 to ::1. Time: 137ms. http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2017-07-08T00%3A51%3A55.458Z 2017-07-08 20:51:55.8429 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:55.8439 Info InstallationManager: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\cache\serverpackages.json 2017-07-08 20:51:55.8959 Info HttpServer: HTTP Response 200 to ::1. Time: 53ms. http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled 2017-07-08 20:51:56.0159 Info SecurityManager: Not registered for feature MBSupporter 2017-07-08 20:51:56.0159 Info HttpServer: HTTP Response 200 to ::1. Time: 519ms. http://localhost:8096/emby/Plugins/SecurityInfo 2017-07-08 20:51:56.0159 Info HttpServer: HTTP GET http://localhost:8096/emby/Plugins/SecurityInfo. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:51:56.0159 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/Plugins/SecurityInfo 2017-07-08 20:52:01.2978 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:52:01.2978 Info HttpServer: HTTP Response 200 to ::1. Time: 9ms. http://localhost:8096/emby/System/Endpoint 2017-07-08 20:52:17.0998 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/system/info/public?format=json. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:17.1448 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 45ms. http://10.10.0.4:8096/emby/system/info/public?format=json 2017-07-08 20:52:17.4498 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/system/info?format=json. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:17.4678 Info App: App Activity: app: Roku SG, version: 3.0.24, deviceId: eee488e1-c1c0-5f69-87d6-4e65d7c5398a, deviceName: Master 2017-07-08 20:52:17.4888 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2017-07-08T00%3A52%3A17.483Z. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:52:17.4888 Info HttpServer: HTTP Response 200 to ::1. Time: 5ms. http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2017-07-08T00%3A52%3A17.483Z 2017-07-08 20:52:17.5538 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 104ms. http://10.10.0.4:8096/emby/system/info?format=json 2017-07-08 20:52:18.0498 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:18.0498 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 2ms. http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe 2017-07-08 20:52:18.4148 Info HttpServer: HTTP POST http://10.10.0.4:8096/emby/Sessions/Capabilities/Full. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:18.4288 Info HttpServer: HTTP Response 204 to 10.10.0.31. Time: 14ms. http://10.10.0.4:8096/emby/Sessions/Capabilities/Full 2017-07-08 20:52:19.9848 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Views?sortby=sortname&EnableImageTypes=Primary,Thumb,Backdrop. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:19.9848 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items?IncludeMediaTypes=Video&EnableImageTypes=Primary,Thumb,Backdrop&sortby=DatePlayed&filters=IsResumable&sortorder=Descending&recursive=true&imagetypelimit=1&limit=30&excludelocationtypes=Virtual. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:20.0028 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Shows/NextUp?userId=9544a5fe514cea76d51529448f457ebe&EnableImageTypes=Primary,Thumb,Backdrop&imagetypelimit=1&limit=30. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:20.1248 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items/Latest?IncludeItemTypes=Episode&EnableImageTypes=Primary,Thumb,Backdrop&groupitems=true&recursive=true&imagetypelimit=1&limit=20&excludelocationtypes=Virtual. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:20.3008 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 304ms. http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items?IncludeMediaTypes=Video&EnableImageTypes=Primary,Thumb,Backdrop&sortby=DatePlayed&filters=IsResumable&sortorder=Descending&recursive=true&imagetypelimit=1&limit=30&excludelocationtypes=Virtual 2017-07-08 20:52:20.3008 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 323ms. http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Views?sortby=sortname&EnableImageTypes=Primary,Thumb,Backdrop 2017-07-08 20:52:20.3348 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 210ms. http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items/Latest?IncludeItemTypes=Episode&EnableImageTypes=Primary,Thumb,Backdrop&groupitems=true&recursive=true&imagetypelimit=1&limit=20&excludelocationtypes=Virtual 2017-07-08 20:52:20.3348 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 336ms. http://10.10.0.4:8096/emby/Shows/NextUp?userId=9544a5fe514cea76d51529448f457ebe&EnableImageTypes=Primary,Thumb,Backdrop&imagetypelimit=1&limit=30 2017-07-08 20:52:21.6368 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items/Latest?ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&includeitemtypes=Movie&groupitems=false&limit=30&excludelocationtypes=Virtual. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:21.6408 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items?includeitemtypes=MusicAlbum&EnableImageTypes=Primary,Thumb,Backdrop&sortby=DateCreated&sortorder=Descending&recursive=true&limit=30. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:21.6408 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 9ms. http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items?includeitemtypes=MusicAlbum&EnableImageTypes=Primary,Thumb,Backdrop&sortby=DateCreated&sortorder=Descending&recursive=true&limit=30 2017-07-08 20:52:21.6408 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 13ms. http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items/Latest?ImageTypeLimit=1&EnableImageTypes=Primary,Thumb,Backdrop&includeitemtypes=Movie&groupitems=false&limit=30&excludelocationtypes=Virtual 2017-07-08 20:52:25.4408 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items/321a4cfb3bdd33c009c52c757009e37b?fields=Overview. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:25.4694 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 29ms. http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items/321a4cfb3bdd33c009c52c757009e37b?fields=Overview 2017-07-08 20:52:27.0419 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Items/321a4cfb3bdd33c009c52c757009e37b/Similar?userId=9544a5fe514cea76d51529448f457ebe&EnableImageTypes=Primary,Thumb,Backdrop&imagetypelimit=1&limit=10&excludelocationtypes=Virtual. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:27.0609 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Shows/NextUp?userId=9544a5fe514cea76d51529448f457ebe&EnableImageTypes=Primary,Thumb,Backdrop&imagetypelimit=1&seriesid=321a4cfb3bdd33c009c52c757009e37b&limit=20. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:27.0679 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 7ms. http://10.10.0.4:8096/emby/Shows/NextUp?userId=9544a5fe514cea76d51529448f457ebe&EnableImageTypes=Primary,Thumb,Backdrop&imagetypelimit=1&seriesid=321a4cfb3bdd33c009c52c757009e37b&limit=20 2017-07-08 20:52:27.0679 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 33ms. http://10.10.0.4:8096/emby/Items/321a4cfb3bdd33c009c52c757009e37b/Similar?userId=9544a5fe514cea76d51529448f457ebe&EnableImageTypes=Primary,Thumb,Backdrop&imagetypelimit=1&limit=10&excludelocationtypes=Virtual 2017-07-08 20:52:27.0919 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Shows/321a4cfb3bdd33c009c52c757009e37b/Seasons?userId=9544a5fe514cea76d51529448f457ebe&EnableImageTypes=Primary,Thumb,Backdrop&imagetypelimit=1&limit=60. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:27.1379 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 46ms. http://10.10.0.4:8096/emby/Shows/321a4cfb3bdd33c009c52c757009e37b/Seasons?userId=9544a5fe514cea76d51529448f457ebe&EnableImageTypes=Primary,Thumb,Backdrop&imagetypelimit=1&limit=60 2017-07-08 20:52:30.3174 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Shows/NextUp?userId=9544a5fe514cea76d51529448f457ebe&EnableImageTypes=Primary,Thumb,Backdrop&imagetypelimit=1&seriesid=321a4cfb3bdd33c009c52c757009e37b&limit=100. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:30.3174 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 4ms. http://10.10.0.4:8096/emby/Shows/NextUp?userId=9544a5fe514cea76d51529448f457ebe&EnableImageTypes=Primary,Thumb,Backdrop&imagetypelimit=1&seriesid=321a4cfb3bdd33c009c52c757009e37b&limit=100 2017-07-08 20:52:31.2060 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items/caa4b0035f224f2f9542e62d3f7b85d1?fields=Overview. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:31.3153 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 109ms. http://10.10.0.4:8096/emby/Users/9544a5fe514cea76d51529448f457ebe/Items/caa4b0035f224f2f9542e62d3f7b85d1?fields=Overview 2017-07-08 20:52:31.7063 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Playback/BitrateTest?size=100000. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:31.7220 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 16ms. http://10.10.0.4:8096/emby/Playback/BitrateTest?size=100000 2017-07-08 20:52:31.8703 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Playback/BitrateTest?size=1000000. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:31.8703 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 0ms. http://10.10.0.4:8096/emby/Playback/BitrateTest?size=1000000 2017-07-08 20:52:32.1526 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Playback/BitrateTest?size=10000000. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:32.2020 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 49ms. http://10.10.0.4:8096/emby/Playback/BitrateTest?size=10000000 2017-07-08 20:52:33.5542 Info HttpServer: HTTP POST http://10.10.0.4:8096/emby/Items/caa4b0035f224f2f9542e62d3f7b85d1/PlaybackInfo?UserId=9544a5fe514cea76d51529448f457ebe&starttimeticks=00000000&maxstreamingbitrate=50196080. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:33.6561 Info App: User policy for Nicole. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2017-07-08 20:52:33.6767 Info App: Profile: Roku SG, Path: E:\TV\Show\Episode.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2017-07-08 20:52:33.6897 Info App: Profile: Roku SG, No direct play profiles found for Path: E:\TV\Show\Episode.mkv 2017-07-08 20:52:33.7097 Info App: RemoteClientBitrateLimit: 5000000, RemoteIp: 10.10.0.31, IsInLocalNetwork: True 2017-07-08 20:52:33.7097 Info App: Profile: Roku SG, Path: E:\TV\Show\Episode.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2017-07-08 20:52:33.7097 Info App: Profile: Roku SG, No direct play profiles found for Path: E:\TV\Show\Episode.mkv 2017-07-08 20:52:33.7097 Info App: RemoteClientBitrateLimit: 5000000, RemoteIp: 10.10.0.31, IsInLocalNetwork: True 2017-07-08 20:52:33.7097 Info App: Profile: Roku SG, Path: E:\TV\Show\Episode.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2017-07-08 20:52:33.7097 Info App: Profile: Roku SG, No direct play profiles found for Path: E:\TV\Show\Episode.mkv 2017-07-08 20:52:33.7407 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 187ms. http://10.10.0.4:8096/emby/Items/caa4b0035f224f2f9542e62d3f7b85d1/PlaybackInfo?UserId=9544a5fe514cea76d51529448f457ebe&starttimeticks=00000000&maxstreamingbitrate=50196080 2017-07-08 20:52:40.1817 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Playback/BitrateTest?size=100000. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:40.1817 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 1ms. http://10.10.0.4:8096/emby/Playback/BitrateTest?size=100000 2017-07-08 20:52:40.4230 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Playback/BitrateTest?size=1000000. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:40.4230 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 16ms. http://10.10.0.4:8096/emby/Playback/BitrateTest?size=1000000 2017-07-08 20:52:40.7137 Info HttpServer: HTTP GET http://10.10.0.4:8096/emby/Playback/BitrateTest?size=10000000. UserAgent: Roku/DVP-7.60 (047.60E04125A) 2017-07-08 20:52:40.7457 Info HttpServer: HTTP Response 200 to 10.10.0.31. Time: 32ms. http://10.10.0.4:8096/emby/Playback/BitrateTest?size=10000000 2017-07-08 20:53:42.5175 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration/encoding. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:53:42.5175 Info HttpServer: HTTP Response 200 to ::1. Time: 8ms. http://localhost:8096/emby/System/Configuration/encoding 2017-07-08 20:53:42.5315 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:53:42.5805 Info HttpServer: HTTP Response 200 to ::1. Time: 49ms. http://localhost:8096/emby/System/Info 2017-07-08 20:54:38.5568 Info HttpServer: HTTP GET http://10.10.0.4:8096/dlna/2079a4eac649448b8a525e7826bb0f48/description.xml. UserAgent: FDSSDP 2017-07-08 20:54:38.5568 Info Dlna: No matching device profile found. The default will need to be used. Cache-Control: no-cache Connection: Keep-Alive Pragma: no-cache Accept: text/xml, application/xml Accept-Encoding: peerdist User-Agent: FDSSDP X-P2P-PeerDist: Version=1.1 X-P2P-PeerDistEx: MinContentInformation=1.0, MaxContentInformation=2.0 Host: 10.10.0.4:8096 2017-07-08 20:54:38.5568 Info HttpServer: HTTP Response 200 to 10.10.0.4. Time: 0ms. http://10.10.0.4:8096/dlna/2079a4eac649448b8a525e7826bb0f48/description.xml 2017-07-08 20:56:33.8811 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/f6c51e6fd330e59d16f4cc52886702e1. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:33.8811 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/Users/f6c51e6fd330e59d16f4cc52886702e1 2017-07-08 20:56:33.9191 Info HttpServer: HTTP GET http://localhost:8096/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:33.9191 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/Sessions 2017-07-08 20:56:33.9191 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:33.9191 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:33.9221 Info HttpServer: HTTP GET http://localhost:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:33.9221 Info HttpServer: HTTP Response 200 to ::1. Time: 7ms. http://localhost:8096/emby/News/Product?StartIndex=0&Limit=4 2017-07-08 20:56:33.9221 Info HttpServer: HTTP GET http://localhost:8096/emby/DisplayPreferences/dashboard?userId=f6c51e6fd330e59d16f4cc52886702e1&client=dashboard. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:33.9221 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/DisplayPreferences/dashboard?userId=f6c51e6fd330e59d16f4cc52886702e1&client=dashboard 2017-07-08 20:56:33.9611 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:33.9611 Info HttpServer: HTTP Response 200 to ::1. Time: 41ms. http://localhost:8096/emby/ScheduledTasks 2017-07-08 20:56:33.9611 Info InstallationManager: Opening C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\cache\serverpackages.json 2017-07-08 20:56:33.9611 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2017-07-08T00%3A56%3A33.898Z. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:33.9671 Info HttpServer: HTTP Response 200 to ::1. Time: 6ms. http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2017-07-08T00%3A56%3A33.898Z 2017-07-08 20:56:33.9671 Info HttpServer: HTTP Response 200 to ::1. Time: 60ms. http://localhost:8096/emby/System/Info 2017-07-08 20:56:33.9671 Info HttpServer: HTTP Response 200 to ::1. Time: 20ms. http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled 2017-07-08 20:56:34.0051 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:34.0051 Info HttpClient: Checking for cache file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\cache\httpclient\f70ca6622474da8168a3b6c06f651a16 2017-07-08 20:56:34.0151 Info HttpServer: HTTP Response 200 to ::1. Time: 10ms. http://localhost:8096/emby/Packages/Updates?PackageType=System 2017-07-08 20:56:37.6001 Info HttpServer: HTTP POST http://localhost:8096/emby/System/Shutdown. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:37.6001 Info HttpServer: HTTP Response 204 to ::1. Time: 1ms. http://localhost:8096/emby/System/Shutdown 2017-07-08 20:56:37.7151 Info HttpServer: HTTP GET http://localhost:8096/web/bower_components/emby-webcomponents/notifications/notificationicon.png. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:37.7151 Info HttpResultFactory: Transmit file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\dashboard-ui\bower_components\emby-webcomponents\notifications\notificationicon.png 2017-07-08 20:56:37.7151 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/web/bower_components/emby-webcomponents/notifications/notificationicon.png 2017-07-08 20:56:37.7151 Info HttpServer: HTTP GET http://localhost:8096/web/bower_components/emby-webcomponents/notifications/badge.png. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36 2017-07-08 20:56:37.7151 Info HttpResultFactory: Transmit file C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\dashboard-ui\bower_components\emby-webcomponents\notifications\badge.png 2017-07-08 20:56:37.7171 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/web/bower_components/emby-webcomponents/notifications/badge.png 2017-07-08 20:56:58.7249 Error SessionManager: Error in SendServerShutdownNotification. *** Error Report *** Version: 3.2.24.0 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application directory: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System MediaBrowser.Model.Net.HttpException: Unable to connect to the remote server at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__22.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Session.SessionManager.<>c__DisplayClass84_0.<<SendServerShutdownNotification>b__2>d.MoveNext() MediaBrowser.Model.Net.HttpException at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__22.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Session.SessionManager.<>c__DisplayClass84_0.<<SendServerShutdownNotification>b__2>d.MoveNext() 2017-07-08 20:56:58.7249 Info Main: Disposing app host 2017-07-08 20:56:58.7249 Info App: Disposing WindowsAppHost 2017-07-08 20:56:58.7249 Info App: Disposing TaskManager 2017-07-08 20:56:58.7249 Info App: Disposing HttpClientManager 2017-07-08 20:56:58.7249 Info App: Disposing IsoManager 2017-07-08 20:56:58.7249 Info App: Disposing InstallationManager 2017-07-08 20:56:58.7249 Info App: Disposing SqliteUserRepository 2017-07-08 20:56:58.7249 Info App: Disposing SqliteDisplayPreferencesRepository 2017-07-08 20:56:58.7249 Info App: Disposing SqliteItemRepository 2017-07-08 20:56:58.7329 Info App: Disposing SqliteFileOrganizationRepository 2017-07-08 20:56:58.7329 Info App: Disposing AuthenticationRepository 2017-07-08 20:56:58.7329 Info App: Disposing LibraryMonitor 2017-07-08 20:56:58.7329 Info App: Disposing ProviderManager 2017-07-08 20:56:58.7329 Info App: Disposing ServerManager 2017-07-08 20:56:58.7329 Info ServerManager: Disposing web socket connections 2017-07-08 20:56:58.7329 Info ServerManager: Disposing http server 2017-07-08 20:56:58.7329 Info HttpServer: Stopping HttpListener... 2017-07-08 20:56:58.7539 Info HttpServer: HttpListener stopped 2017-07-08 20:56:58.7539 Info App: Disposing ImageProcessor 2017-07-08 20:56:58.7539 Info App: Disposing MediaSourceManager 2017-07-08 20:56:58.7539 Info App: Disposing LiveTvManager 2017-07-08 20:56:58.7539 Info App: Disposing ContentDirectory 2017-07-08 20:56:58.7539 Info App: Disposing MediaReceiverRegistrar 2017-07-08 20:56:58.7539 Info App: Disposing MediaEncoder 2017-07-08 20:56:58.7539 Info App: Disposing SharingRepository 2017-07-08 20:56:58.7539 Info App: Disposing ActivityRepository 2017-07-08 20:56:58.7539 Info App: Disposing SqliteNotificationsRepository 2017-07-08 20:56:58.7539 Info App: Disposing MovieDbProvider 2017-07-08 20:56:58.7539 Info App: Disposing EmbyTV 2017-07-08 20:56:58.7539 Info App: Disposing OpenSubtitleDownloader 2017-07-08 20:56:58.7539 Info App: Disposing ApiEntryPoint 2017-07-08 20:56:58.7539 Info App: Disposing ServerEntryPoint 2017-07-08 20:56:58.7539 Info App: Disposing CleanMissingEpisodesEntryPoint 2017-07-08 20:56:58.7539 Info App: Disposing Notifications 2017-07-08 20:56:58.7689 Info App: Disposing WebSocketNotifier 2017-07-08 20:56:58.7689 Info App: Disposing NewsEntryPoint 2017-07-08 20:56:58.7689 Info App: Disposing EntryPoint 2017-07-08 20:56:58.7689 Info App: Disposing FileOrganizationNotifier 2017-07-08 20:56:58.7689 Info App: Disposing AutomaticRestartEntryPoint 2017-07-08 20:56:58.7689 Info App: Disposing KeepServerAwake 2017-07-08 20:56:58.7689 Info App: Disposing LibraryChangedNotifier 2017-07-08 20:56:58.7689 Info App: Disposing LoadRegistrations 2017-07-08 20:56:58.7689 Info App: Disposing RecordingNotifier 2017-07-08 20:56:58.7689 Info App: Disposing RefreshUsersMetadata 2017-07-08 20:56:58.7689 Info App: Disposing ServerEventNotifier 2017-07-08 20:56:58.7689 Info App: Disposing StartupWizard 2017-07-08 20:56:58.7689 Info App: Disposing SystemEvents 2017-07-08 20:56:58.7689 Info App: Disposing UdpServerEntryPoint 2017-07-08 20:56:58.7689 Info App: Disposing UsageEntryPoint 2017-07-08 20:56:58.7689 Info App: Disposing UserDataChangeNotifier 2017-07-08 20:56:58.7689 Info App: Disposing ChannelsEntryPoint 2017-07-08 20:56:58.7689 Info App: Disposing ActivityLogEntryPoint 2017-07-08 20:56:58.7829 Info App: Disposing DlnaProfileEntryPoint 2017-07-08 20:56:58.7829 Info App: Disposing DlnaEntryPoint 2017-07-08 20:57:01.0969 Info App: Disposing EntryPoint 2017-07-08 20:57:01.0969 Info App: Disposing IntrosEntryPoint 2017-07-08 20:57:01.0969 Info App: Disposing PluginSecurityManager 2017-07-08 20:57:01.0969 Info App: Disposing ConnectEntryPoint 2017-07-08 20:57:01.0969 Info App: Disposing SyncManagerEntryPoint 2017-07-08 20:57:01.0969 Info App: Disposing SyncNotificationEntryPoint 2017-07-08 20:57:01.0969 Info App: Disposing PluginSecurityManager 2017-07-08 20:57:01.0969 Info App: Disposing LibraryMonitorStartup 2017-07-08 20:57:01.0969 Info App: Disposing ExternalPortForwarding 2017-07-08 20:57:01.0969 Info Main: App host dispose complete 2017-07-08 20:57:01.0969 Info Main: Calling Application.Exit
ebr 16335 Posted July 10, 2017 Posted July 10, 2017 No way to do file attachment? Hit "More Reply Options" button... What version of the Roku app? Can you try the beta?
Solution ensign.fodder 1 Posted July 14, 2017 Author Solution Posted July 14, 2017 So added beta client to Roku that previously could not play a file and it played fine. Let me know if you want the logs and thanks! 1
Bamit 8 Posted July 17, 2017 Posted July 17, 2017 (edited) Just purchased a membership today so I could try the Live TV function. Was disappointed to discover that it does not work on my Roku 3. After reading the comments on this thread, I found that after installing the Beta channel, the Live TV did work for me on the Roku 3. The playlist however still does not work on either the Normal Emby channel or the Beta one. The playlists do work under the Web UI though. Edited July 18, 2017 by Bamit
Luke 42242 Posted July 17, 2017 Posted July 17, 2017 Hi @@Bamit, welcome. We're sorry to hear about this. Can you describe your issue with a little more detail? We'd like to learn exactly what you mean by "doesn't work". Thanks !
Bamit 8 Posted July 17, 2017 Posted July 17, 2017 Referring to the playlist? If so, when I choose the playlist library from the Roku channel, it is empty. When choosing it from a Web browser (Firefox in my case) it shows the Two Playlists that I have created, and they can be selected normally.
ebr 16335 Posted July 18, 2017 Posted July 18, 2017 Are they video playlists? If so, those have not yet been implemented in the new app. Audio playlists are fully supported, however.
Bamit 8 Posted July 18, 2017 Posted July 18, 2017 (edited) Thanks for the quick answer. Yes, they are Video playlists that I had created. Is this something on the "To Do" list? Edited July 18, 2017 by Bamit
ebr 16335 Posted July 18, 2017 Posted July 18, 2017 Thanks for the quick answer. Yes, they are Video playlists that I had created. Is this something on the "To Do" list? Should be available very soon. Edit: in fact, update or install the beta version now. 1
Bamit 8 Posted July 18, 2017 Posted July 18, 2017 (edited) Works perfectly! Edited July 18, 2017 by Bamit
