JrD 22 Posted July 9, 2017 Posted July 9, 2017 Hey i can connect to my server by the web app or even by emby connect i can click the links and it opens fine and even on kodi but just not on the web app every time i try to get in by the web app i get this I have tried checking my port fowarding but its all fine it worked before it looks like this here is the dashboard
Karlsson 0 Posted July 9, 2017 Posted July 9, 2017 Me neither. But I can connect using the local address and port. And the android app "work". I say "work" because there are backdrop images as icons all over the place... Thanks Emby Team... what a nice "feature"...
Luke 42242 Posted July 10, 2017 Posted July 10, 2017 Hey i can connect to my server by the web app or even by emby connect i can click the links and it opens fine and even on kodi but just not on the web app every time i try to get in by the web app i get this connection error.JPG I have tried checking my port fowarding but its all fine it worked before it looks like this At&t port fowarding.JPG here is the dashboard emby eroor dashboard.JPG Hi there @@JrD, I would suggest checking out our Connection Troubleshooter. Please try the steps listed there and let us know exactly what succeeds and what fails. Thanks !
Luke 42242 Posted July 10, 2017 Posted July 10, 2017 Me neither. But I can connect using the local address and port. And the android app "work". I say "work" because there are backdrop images as icons all over the place... Thanks Emby Team... what a nice "feature"... Hi there @@Karlsson, I would suggest checking out our Connection Troubleshooter. Please try the steps listed there and let us know exactly what succeeds and what fails. Thanks !
Karlsson 0 Posted July 11, 2017 Posted July 11, 2017 Hi there @@Karlsson, I would suggest checking out our Connection Troubleshooter. Please try the steps listed there and let us know exactly what succeeds and what fails. Thanks ! Now why would I do that? Everything worked fine before, I didn't change anything - you did. Just fix whatever you screwed up. Thanks
Luke 42242 Posted July 11, 2017 Posted July 11, 2017 Hi @@Karlsson, we did not change anything. We would like to team up with you to help you investigate this. Thanks !
Karlsson 0 Posted July 12, 2017 Posted July 12, 2017 Great now nothing work.. Hi @@Karlsson, we did not change anything. We would like to team up with you to help you investigate this. Thanks ! Sure... is that why backdrops suddenly started to show up instead of folders a few days ago...? Btw now nothing work except localhost...
Luke 42242 Posted July 13, 2017 Posted July 13, 2017 Hi @@Karlsson, what version of Emby Server are you running?
ShadowKindjal 21 Posted July 23, 2018 Posted July 23, 2018 (edited) I apologize for responding to an old thread but I seem to have the same exact issue. I have gone through the Connection Troubleshooter guide and the only time I am unable to connect to my server is when I'm using Emby connect and only when using the web app I tried using the web app to login to my server but I keep getting the following error message We're unable to connect to the selected server right now. Please ensure it is running and try again. However, my server is up and running and works when I use the domain I have assigned to it in my dashboard. Edited July 23, 2018 by nharmon
Luke 42242 Posted July 24, 2018 Posted July 24, 2018 Does your emby server dashboard display the correct remote address?
KojoZero 0 Posted July 24, 2018 Posted July 24, 2018 I'm not sure if this may be helpful but make sure that you are using http, not https, for emby.
Luke 42242 Posted July 24, 2018 Posted July 24, 2018 Well yes, if you're using https, then the problem could be certificate related. Once we rule out connectivity, then my next set of questions would head in that direction.
ShadowKindjal 21 Posted July 24, 2018 Posted July 24, 2018 (edited) Yes, my console displays the correct server address in the dashboard and I was able to connect to that address just fine over HTTP. My issue is actually resolved now. There seemed to be an issue with the lastest beta build I was running (3.6.0.2). Going back to the current stable build (3.5.0.0) is what ended up resolving the issue. That was the only thing I changed. I also had issues inviting emby connect accounts to my server while I was on 3.6.0.2 Edited July 24, 2018 by nharmon
Luke 42242 Posted July 24, 2018 Posted July 24, 2018 That sounds coincidental because given that we just had a stable release, the beta build is nearly identical at this point.
ShadowKindjal 21 Posted July 24, 2018 Posted July 24, 2018 There's a great chance that it was coincidental. Should I try to recreate the issue?
ShadowKindjal 21 Posted July 25, 2018 Posted July 25, 2018 Well I haven't made any changes to my server as of yet and it seems that the web app is not working again. This is the same installation that was working yesterday as of my last post.
Luke 42242 Posted July 25, 2018 Posted July 25, 2018 Make sure the server dashboard shows the correct local and remote addresses.
ShadowKindjal 21 Posted July 25, 2018 Posted July 25, 2018 I did, it is indeed showing the correct addresses.
Luke 42242 Posted July 25, 2018 Posted July 25, 2018 If you manually enter the address, does that connect?
ShadowKindjal 21 Posted July 25, 2018 Posted July 25, 2018 If I manually enter the web address showing in my dashboard it connects right away
ShadowKindjal 21 Posted July 26, 2018 Posted July 26, 2018 Yes, if I manually enter the address it connects
ShadowKindjal 21 Posted July 30, 2018 Posted July 30, 2018 Sorry, I don't know what happened with the last response but no, this is the same server I've been using for about a year now besides the updates I've been installing. Just last night I made the switch to HTTPS and for some reason I could only connect to my server via HTTP. IT wasn't until I performed a restart did HTTPS start working and the web app as well. When I originally stated I was having issues with the web app I was strictly running my server over HTTP and having issues.
