mitbac 2 Posted February 21, 2014 Posted February 21, 2014 I do not know if a thread about this already exists. I apologise if that is the case. I really like how MBT makes raw rating visible (i.e. Rotten Tomatoes/IMDB rating) visible. The star value of 1-5 doesn't really mean anything. Also information about Similar movies, and reviews is something I find very useable. Is thos something that could be implemented? Thank you.
ebr 16343 Posted February 21, 2014 Posted February 21, 2014 Reviews will eventually be done. Similar movies is implemented now but will probably also be added to the detail screen at some point. To see similar, bring up the context menu on an item (* key) and select "Similar To..."
mitbac 2 Posted February 22, 2014 Author Posted February 22, 2014 Ok. That sounds great. Do you have an opinion about making RT rating or the like visible? I am new to the community. Is there a preference from the other users to have the 5 star rating? I hadn't noticed the Similar To from the context menu. Thanks for the tip.
ebr 16343 Posted February 22, 2014 Posted February 22, 2014 The 5-star rating is just what we've always had from way back when. RT will eventually be added as well.
