Pfalznase 1 Posted July 8, 2017 Posted July 8, 2017 Seid Upgrade auf die Version 3.2.22.0-1 auf meinem Synology NAS lässt sich das embyPaket nicht mehr starten, nach klicken auf "Ausführen" rödelt die Synology etwas danach steht "angehalten" Hat jemand ne Idee woran das liegen könnte mit der Version 3.2.20 hatte ich dieses Verhalten nicht.
Pfalznase 1 Posted July 8, 2017 Author Posted July 8, 2017 upgrade to version 3.2.22.0-1 on my Synology NAS the embyPaket can not be started, To click 'Run' Synology something then is 'stopped' Does anyone have an idea what could be the with version 3.2.20 I did not have this behavior.
Luke 42241 Posted July 8, 2017 Posted July 8, 2017 @Pfalznase Hallo, da kannst du das Fjord-Server-Log anhängen? Sie können lernen, wie man das hier macht: Https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/Vielen Dank !
Pfalznase 1 Posted July 8, 2017 Author Posted July 8, 2017 @Pfalznase Hallo, da kannst du das Fjord-Server-Log anhängen? Sie können lernen, wie man das hier macht: Https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Vielen Dank ! Wo finde ich das?
cablhh 0 Posted July 8, 2017 Posted July 8, 2017 (edited) Same for me on a DS916+ (just sent the logs via ssh) Edited July 8, 2017 by cablhh
Luke 42241 Posted July 8, 2017 Posted July 8, 2017 @@cablhh can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ thanks.
cablhh 0 Posted July 8, 2017 Posted July 8, 2017 Hi i just sent it via SSH as described - sorry forgot the filename in the first Posting : sendlogs_Server_synology_braswell_916+_20170708T191225UTC.tgz
cablhh 0 Posted July 8, 2017 Posted July 8, 2017 Hi this should be the latest server log ... server-63635143708.txt
Luke 42241 Posted July 8, 2017 Posted July 8, 2017 can you go to /var/packages/EmbyServer/target/var/plugins and remove all plugin .dll files. see if that allows the server to start. thanks.
Luke 42241 Posted July 8, 2017 Posted July 8, 2017 Hi ... the server starts without the plugins ... Great. Can you try adding some back in order to narrow it down to which one is causing the issue? thanks.
cablhh 0 Posted July 8, 2017 Posted July 8, 2017 I checked all and it was the Vimeo plugin - which seems to be out of date and as far as i have seen it isn´t provided anymore Everything else seems to work ...Server is up. Thank you
Pfalznase 1 Posted July 9, 2017 Author Posted July 9, 2017 (edited) @Pfalznase Hallo, da kannst du das Fjord-Server-Log anhängen? Sie können lernen, wie man das hier macht: Https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Vielen Dank ! @ luke Ich habe heute noch mals das emby-server paket frisch installiert und nach recherche im www hab ich mit Winscp das log kopiert ich hoffe es ist das benötigte. Google Translate: "I still times freshly installed the Emby-server package and after recherche at www I have with the Winscp log copied hope it's the need." start-stop-status_20170709.log Edited July 9, 2017 by Pfalznase
Luke 42241 Posted July 9, 2017 Posted July 9, 2017 @ luke Ich habe heute noch mals das emby-server paket frisch installiert und nach recherche im www hab ich mit Winscp das log kopiert ich hoffe es ist das benötigte. Google Translate: "I still times freshly installed the Emby-server package and after recherche at www I have with the Winscp log copied hope it's the need." What is your actual problem?
Pfalznase 1 Posted July 9, 2017 Author Posted July 9, 2017 (edited) What is your actual problem? upgrade to version 3.2.22.0-1 on my Synology NAS the embyPaket can not be started, To click 'Run' Synology something then is 'stopped' Does anyone have an idea what could be the with version 3.2.20 I did not have this behavior. Emby- server do not start on my synology DS212+ emby-server version 3.2.22.0-1 Edited July 9, 2017 by Pfalznase
Luke 42241 Posted July 9, 2017 Posted July 9, 2017 Emby- server do not start on my synology DS212+ emby-server version 3.2.22.0-1 Can you please follow the instructions in post #6? Thanks !
HBvier 0 Posted July 10, 2017 Posted July 10, 2017 habe selbe Problem, auch eine DS212+, Emby Server steht auf "angehalten" Wie komme ich da zu einem Log? Bringt eine neue Installation was?
Luke 42241 Posted July 10, 2017 Posted July 10, 2017 @@HBvier Hallo, da kannst du das Fjord-Server-Log anhängen? Sie können lernen, wie man das hier macht: Https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/Vielen Dank !
Pfalznase 1 Posted July 10, 2017 Author Posted July 10, 2017 (edited) habe selbe Problem, auch eine DS212+, Emby Server steht auf "angehalten" Wie komme ich da zu einem Log? Bringt eine neue Installation was? Ich habe Emby schon gefühlte 100x neu installiert, hab das Log (hoffe das richtige) gepostet und keine und keine Antwort darauf erhalten, anscheinend lesen die hier nicht richtig mit. Ich habe mich im WWW erst schlau machen müssen da der Post #6 hier nicht weiterhilft, habe mir WINSCP heruntergeladen und in der DISKSTATION eingeloggt. @ Luke In dem im Post #10 beschriebenen Ornder befindet sich kein Ordner plugins. Ich hatte mir gerade 1 Monat Premiere gekauft als das update kam Hier nochmals das Log das ich jedoch schon weiter oben gepostet hatte. start-stop-status_20170709.log Edited July 10, 2017 by Pfalznase
HBvier 0 Posted July 10, 2017 Posted July 10, 2017 (edited) danke für die Antwort, dann erspare ich mir die Neuinstallation, habe auch Premiere, echt ärgerlich :-/ Edited July 10, 2017 by HBvier
Luke 42241 Posted July 10, 2017 Posted July 10, 2017 danke für die Antwort, dann erspare ich mir die Neuinstallation, habe auch Premiere, echt ärgerlich :-/ Waren Sie in der Lage, es mit den oben genannten Informationen zu lösen?
