horstepipe 423 Posted July 8, 2017 Posted July 8, 2017 Hey When starting Kodi and a manual sync is being triggered for some reason, you can go on using Kodi, the sync processes in the background. Can you make it behave the same when you manually start a manual sync? At the moment you can't do anything in Kodi after manually starting a manual sync. Here, the last step of the manual sync is "Comparing episodes" which goes its way from 1 to 100% fine, but then stays on 100% for 30 minutes. Is it possible to improve the percentage report so the users can better estimate how long the sync still takes? Best regards
Angelblue05 4132 Posted July 8, 2017 Posted July 8, 2017 (edited) The manual sync doesn't show the "gathering" step, that's why it seems to be stuck on 100%. In truth, it's gathering the next section of your content to be compared, (music I believe). Anyway, I'll see what I can do about improving this in the long run, thanks for the feedback Edited July 8, 2017 by Angelblue05 1
