blade005 185 Posted July 7, 2017 Posted July 7, 2017 I guess the question is why when adding or removing a folder from a library is Emby starting a media scan on its own without you telling it to? If it didn't do that then if you do remove the wrong folder you can fix it before you scan. @@dcook Emby kicks off library scan automatically after adding or removing a folder. No time to correct the issue of Emby removing a folder path that you didn't select with the Library UI.
dcook 303 Posted July 7, 2017 Posted July 7, 2017 Exactly I don't think it should be starting a library scan automatically, if you add or remove folders. Emby should wait until you click scan library or the next scheduled task arrives.
CBers 7542 Posted July 7, 2017 Posted July 7, 2017 Exactly I don't think it should be starting a library scan automatically, if you add or remove folders. Emby should wait until you click scan library or the next scheduled task arrives. Would disabling Real-time Monitoring fix that?
Deathsquirrel 745 Posted July 7, 2017 Posted July 7, 2017 Exactly I don't think it should be starting a library scan automatically, if you add or remove folders. Emby should wait until you click scan library or the next scheduled task arrives. Then' we'd see a string of complaints about how a folder was added to a library and not scanned.
dcook 303 Posted July 7, 2017 Posted July 7, 2017 @@CBers I have real time monitoring turned off and if I add or remove a folder Emby still starts a Library Scan on its own without me initiating it. @@Deathsquirrel Why would one assume that by adding a folder or removing a folder Emby would do a library scan? They have the manual links you click on to start a scan, and you have scheduled tasks where you can automated a scan.
Luke 42203 Posted July 7, 2017 Posted July 7, 2017 If we didn't start a library scan after making changes, then it would lead to lots of reports of "I added a new folder and it's not working". So that is why we do it.
blade005 185 Posted July 7, 2017 Posted July 7, 2017 If we didn't start a library scan after making changes, then it would lead to lots of reports of "I added a new folder and it's not working". So that is why we do it. @@Luke Agree. The issue of the Library UI removing the incorrect folder selected should not be 'fixed' by not starting a Library scan when a folder is added or removed. That would create more user issues. I think what most of us in this thread have encountered in the last few months is that we will select a folder in a Library collection that may be the third one down in the UI list and click remove. The Library UI then removes the folder path at the top of the list, which we didn't select, and a library scan is then kicked off. Happened to me a few months back and I had over 2,500 movies removed from my library after the scan. That was a long and painful recovery process. Since then, I only feel comfortable removing a folder in a library by manually editing the OPTIONS.XML file associated with that library and removing the folder path.
horstepipe 422 Posted July 8, 2017 Author Posted July 8, 2017 @@Luke When fixing the UI-bug, please add the folder name to the "Are you sure you want to delete the folder?" question as an additional security measure 1
Spaceboy 2573 Posted July 8, 2017 Posted July 8, 2017 @@Luke When fixing the UI-bug, please add the folder name to the "Are you sure you want to delete the folder?" question as an additional security measure this is exactly what is needed
tosa65 17 Posted August 1, 2017 Posted August 1, 2017 (edited) Fakt is: Emby löscht den falschen Ordner/Verzeichnis. PUNKT !!! Und das is ein BUG... Was soll die dumme Diskussion, ob Ihr das tut oder nicht... Edited August 1, 2017 by tosa65
