teiva 18 Posted July 4, 2017 Posted July 4, 2017 (edited) Open Media Vault 3.0.81 Debian 4.9.30 Emby 3.2.20 via docker Actual Behavior: By the morning, I can't connect to my server locally for the last 2 days which is every morning since I move my setup to OMV v3. According to the CLI emby-server is running and docker service is running as well. root@server:~# emby-server Already running. root@server:~# systemctl status docker.service ● docker.service - Docker Application Container Engine Loaded: loaded (/lib/systemd/system/docker.service; enabled) Active: active (running) since Mon 2017-07-03 16:59:53 PDT; 14h ago Docs: https://docs.docker.com Main PID: 3314 (dockerd) CGroup: /system.slice/docker.service ├─3314 /usr/bin/dockerd -H fd:// ├─3323 docker-containerd -l unix:///var/run/docker/libcontainerd/d... └─8701 docker-containerd-shim c5ba9491f3f9ce285b366b969380e63fa9d7... Jul 03 17:00:55 server systemd[1]: [/lib/systemd/system/docker.service:25]...e' Jul 03 17:00:56 server systemd[1]: [/lib/systemd/system/docker.service:25]...e' Jul 03 17:00:56 server systemd[1]: [/lib/systemd/system/docker.service:25]...e' Jul 03 17:00:56 server systemd[1]: [/lib/systemd/system/docker.service:25]...e' Jul 03 17:00:56 server systemd[1]: [/lib/systemd/system/docker.service:25]...e' Jul 03 17:00:57 server systemd[1]: [/lib/systemd/system/docker.service:25]...e' Jul 03 17:12:38 server systemd[1]: [/lib/systemd/system/docker.service:25]...e' Jul 03 17:12:49 server systemd[1]: [/lib/systemd/system/docker.service:25]...e' Jul 03 17:16:51 server systemd[1]: [/lib/systemd/system/docker.service:25]...e' Jul 03 17:16:51 server systemd[1]: [/lib/systemd/system/docker.service:25]...e' Hint: Some lines were ellipsized, use -l to show in full. The issue is temporarily resolved when I reboot my box or upgrade emby-server. See attached log. Is there some incompatibility issue with my mono.exe version? I see a mono.exe issue within radarr too. mono version is less than 3.10, upgrade for improved stability root@server:~# dpkg -s mono mono-2.0-gac mono-complete monodoc-appindicator3-0.1-manual monodoc-gstreamer-manual monodoc-mono-upnp-manual monodoc-soup2.4-manual mono-fpm-server mono-runtime-dbg mono-utils mono-2.0-service mono-csharp-shell monodoc-avahi-manual monodoc-gtk2.0-manual monodoc-mono-zeroconf-manual monodoc-taglib-manual mono-gac mono-runtime-sgen mono-vbnc mono-4.0-gac mono-dbg monodoc-banshee-manual monodoc-gtk3.0-manual monodoc-mysql-manual monodoc-taoframework-manual mono-gmcs monotone mono-xbuild mono-4.0-service mono-devel monodoc-base monodoc-gudev-manual monodoc-newtonsoft-json-manual monodoc-webkitgtk2.0-manual mono-jay monotone-doc mono-xsp mono-addins-utils monodevelop monodoc-browser monodoc-hexbox-manual monodoc-notify3.0-manual monodoc-webkitgtk3.0-manual mono-mcs monotone-extras mono-xsp2 mono-apache-server monodevelop-database monodoc-clutter-manual monodoc-http monodoc-notify-sharp-manual monodoc-webkit-manual monopd monotone-server mono-xsp2-base mono-apache-server2 monodevelop-monogame monodoc-gdata-manual monodoc-hyena-manual monodoc-nunit-manual monodoc-zeitgeist-manual mono-profiler monotone-viz mono-xsp4 mono-apache-server4 monodevelop-nunit monodoc-gkeyfile-manual monodoc-manual monodoc-opentk-manual mono-fastcgi-server mono-runtime mono-tools-devel mono-xsp4-base mono-basic-dbg monodevelop-versioncontrol monodoc-gmime2.6-manual monodoc-mono-fuse-manual monodoc-poppler-manual mono-fastcgi-server2 mono-runtime-boehm mono-tools-gui monobristol mono-dmcs monodoc-gnome-keyring-manual monodoc-monogame-manual monodoc-semweb-manual mono-fastcgi-server4 mono-runtime-common mono-upnp-bin Apparently I have 2 versions of mono. root@server:~# mono -V Mono JIT compiler version 3.2.8 (Debian 3.2.8+dfsg-10) Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com TLS: __thread SIGSEGV: altstack Notifications: epoll Architecture: amd64 Disabled: none Misc: softdebug LLVM: supported, not enabled. GC: sgen log.txt Edited July 4, 2017 by teiva
Luke 42245 Posted July 5, 2017 Posted July 5, 2017 I would suggest removing all plugin dll files from /config/plugins and then seeing if the issue persists. thanks !
Luke 42245 Posted July 5, 2017 Posted July 5, 2017 As far as mono goes, 3.10 is really old now. I would recommend 4.8.1.
Solution teiva 18 Posted July 11, 2017 Author Solution Posted July 11, 2017 Issue seems resolved after upgrading my server to 3.2.22. I didn't remove any plugins because I couldn't find a plugin folder on the linux docker via grep. Either way I've only installed 1 plugin (pushbullet). My package manager says 3.2.8 mono is the most update package for my linux distro. *shrug* I'm still learning how to use linux. Thank you for your suggestions, Luke.
Luke 42245 Posted July 11, 2017 Posted July 11, 2017 Thanks for the feedback. Please be advised that we are not supporting mono 3.2.8 anymore, but if it's working for you then that is good news to hear. I would suggest playing it safe and not installing too many plugins. Thanks.
