Luke 42203 Posted November 6, 2017 Posted November 6, 2017 can you provide a sample video for testing? thanks.
drikosv8 25 Posted November 6, 2017 Author Posted November 6, 2017 I could create a user for you on my server so you can test the file, would that help? Tell me how can I send you the username and password with the server address? Eu poderia criar um usuário para você no meu servidor para que você possa testar o arquivo, isso ajudaria? Diga-me como posso enviar-lhe o nome de usuário e a senha com o endereço do servidor?
Luke 42203 Posted November 6, 2017 Posted November 6, 2017 I'd like to test the file on my server. is that possible? thanks.
drikosv8 25 Posted November 6, 2017 Author Posted November 6, 2017 @@Luke I hosted the file for you to download. The link is below. https://e-nautia.com/disk/download.php?id=7593633 Set up your user in the configuration of the user in the dashboard to 1 mega so that you analyze exactly like the client and I did. I'll be waiting and thank you. Eu hospedei o arquivo para você baixar. O link está abaixo. https://e-nautia.com/disk/download.php?id=7593633 Configure seu usuário na configuração do usuário no painel de controle para 1 mega para que você analise exatamente como o cliente e eu fiz. Estarei esperando e obrigado.
Luke 42203 Posted November 6, 2017 Posted November 6, 2017 Ok, i have the video. So how do I reproduce? I start playing in Chrome from the beginning, right? And then at what point does it fall out of sync? thanks.
drikosv8 25 Posted November 6, 2017 Author Posted November 6, 2017 @@Luke Yes, you will set up in the users panel, by 1 mega to transcode, exactly in that exact panel field, as well as the attached image. And it reproduces from the beginning the episode. There is no point right, but during a view there will be a loss of audio sync. @@Luke Sim, você irá configurar no painel de usuários, por 1 mega para transcodificar, exatamente nesse campo de painel exato, bem como a imagem anexada. E reproduz desde o início o episódio. Não há nenhum ponto certo, mas durante uma exibição haverá uma perda de sincronização de áudio.
drikosv8 25 Posted November 7, 2017 Author Posted November 7, 2017 @@Luke Did you see the problem? @@LukeVocê viu o problema?
drikosv8 25 Posted November 7, 2017 Author Posted November 7, 2017 @@Luke I'm sorry, I just thought you had not seen my message. I'll be waiting, my friend. thank you
drikosv8 25 Posted November 12, 2017 Author Posted November 12, 2017 @@Luke The problem continues, complaint all the time here !! occurs only when transcoding using google chrome. I need a solution, I'm going to lose the client. @@Luke O problema continua, queixa o tempo todo aqui! ocorre apenas quando transcodificação usando google chrome. Preciso de uma solução, vou perder o cliente.
Luke 42203 Posted November 12, 2017 Posted November 12, 2017 I can reproduce in chrome desktop but I am not sure yet what the solution is.
drikosv8 25 Posted November 12, 2017 Author Posted November 12, 2017 If I understood correctly, were you able to reproduce the audio delay on your local machine? This is already a breakthrough, now just map the problem and apply a solution. I will be waiting and if there is anything I can do to help you, I am at your disposal. Thank you Se entendi corretamente, você conseguiu reproduzir o atraso de áudio em sua máquina local? Isso já é um avanço, agora apenas mapeie o problema e aplique uma solução. Estarei esperando e se houver algo que eu possa fazer para ajudá-lo, estou à sua disposição. Obrigado
Luke 42203 Posted November 12, 2017 Posted November 12, 2017 I am looking into it but the tricky part is that it works fine in other browsers such as Microsoft Edge.
drikosv8 25 Posted November 13, 2017 Author Posted November 13, 2017 I understand, this happens only in google chrome, but it is the most used and has been a big problem, my friend. Eu entendo, isso acontece apenas no google chrome, mas é o mais usado e tem sido um grande problema, meu amigo.
