Uuugh 4 Posted July 1, 2017 Posted July 1, 2017 Hi, I'm a long time user with Android, Roku, and Windows Apps. I now also have Emby installed on a UN60KS8000 TV. The app is great with the following "flaw".... On all other apps, the guide is by default left-aligned. For example, if it is 8:15 PM, then on the guide 8:00PM (or 8:15) is to the leftmost of the screen and you can scroll right for future recordings. On the Samsung TV app the current time is unnaturally center-aligned. So if the time is 8:35, the guide will bounce around as you scroll down between 30-minute and 60-minute shows. Hopefully that made sense. Thanks for the great work! 1
Uuugh 4 Posted July 14, 2017 Author Posted July 14, 2017 Thanks Luke. I've decided that you either have supernatural powers or are more than one person. There is no other explanation for your fast responses and the awesomeness of Emby. Thanks for your work.
zigzagtshirt 55 Posted September 18, 2017 Posted September 18, 2017 Issue still persists. Please fix. Thanks.
