fc7 123 Posted July 13, 2017 Author Posted July 13, 2017 @Luke: rolled back to 3.2.19.0. Please find attached both Emby server and ffmpeg logs. Playback test last for around one minute and then I manually stopped it. Client browser and ffmpeg versions remain exactly the same. The only change is Emby server version. Let me know if you need anything. ffmpeg-transcode-c6600989-e9f1-4791-85ac-858ab10bdc1d.txt server-63635579579.txt
fc7 123 Posted July 25, 2017 Author Posted July 25, 2017 *bump* Any news about this bug? Just updated to 3.2.26.0 but the problem remains the same. Did the logs provided above helped in any way to understand the cause of the problem?
fc7 123 Posted August 9, 2017 Author Posted August 9, 2017 *bump* @Luke: Any news about this bug? Any useful information in the logs provided above? I need to stay in 3.2.19 until this is solved.
Luke 42245 Posted August 26, 2017 Posted August 26, 2017 Can you expose your HDHR externally and then send me the url? then i can test personally. thanks.
fc7 123 Posted August 28, 2017 Author Posted August 28, 2017 Can you expose your HDHR externally and then send me the url? then i can test personally. thanks. Yes. That shouldn't be a problem. I guess you will need to reach HDHR http port plus a port for a radio channel correct? Let me know and I will set it up ASAP. Thanks
Luke 42245 Posted August 28, 2017 Posted August 28, 2017 I think just one for the entire HDHR is fine.
fc7 123 Posted August 29, 2017 Author Posted August 29, 2017 I think just one for the entire HDHR is fine. That is not going to be that easy it seems. Let me send you a PM with the information on how to connect and see if it works.
fc7 123 Posted September 3, 2017 Author Posted September 3, 2017 @Luke: did you read my PMs with the details to connect to the HDHR I sent a few days ago? Did you succeed to connect? Please let me know if you still need access to it since I'm not comfortable while my HDHR is exposed to the Internet for days. Thanks.
Solution Luke 42245 Posted September 6, 2017 Solution Posted September 6, 2017 It's resolved for the next release, thanks. 1
fc7 123 Posted September 6, 2017 Author Posted September 6, 2017 It's resolved for the next release, thanks. Brilliant news @@Luke! Do you still need access to the HDHR? Sent from my iPhone using Tapatalk
fc7 123 Posted September 22, 2017 Author Posted September 22, 2017 I can confirm that the problem is solved in 3.2.32.0. Thanks a lot @@Luke!
