Spaceboy 2573 Posted July 15, 2017 Author Posted July 15, 2017 (edited) yes nssm with those arguments is fine. to work on the security we need to add a few things. now this is where i am not sure how it works in caddy. whether you can add it as a global setting or have to add each reverse proxy block individually. so like you had before notice i changed x-frame-options otherwise all your services wont work within the organizr header /emby { -Server Strict-Transport-Security "max-age=31536000;" Referrer-Policy "strict-origin" X-XSS-Protection "1; mode=block" X-Content-Type-Options "nosniff" X-Frame-Options "SAMEORIGIN" the original caddyfile was just header / i added emby after the / while i was trying to get the other services working. so should this be header / to apply the security settings globally? and should these changes allow my remote user to log in? Edited July 15, 2017 by Spaceboy
Swynol 375 Posted July 15, 2017 Posted July 15, 2017 (edited) ok that makes sense. yes just use / to add it globally. I'm not really sure why your remote user cant login with his fire tv stick. i've used one remotely using a reverse proxy and https and it worked fine. Just access your diskstation you can add proxy /diskstation 192.168.1.4:5000 { transparent websocket } aslong as your diskstation has a login, otherwise your opening it to the internet. on the firetv you should be navigating to https://mydomain.com/emby dont need to add any port numbers. once you have added the security headers: test it at https://securityheaders.io/ should get a A- at least Edited July 15, 2017 by Swynol
Spaceboy 2573 Posted July 15, 2017 Author Posted July 15, 2017 ok that makes sense. yes just use / to add it globally. I'm not really sure why your remote user cant login with his fire tv stick. i've used one remotely using a reverse proxy and https and it worked fine. Just access your diskstation you can add proxy /diskstation 192.168.1.4:5000 { transparent websocket } aslong as your diskstation has a login, otherwise your opening it to the internet. on the firetv you should be navigating to https://mydomain.com/emby dont need to add any port numbers. once you have added the security headers: test it at https://securityheaders.io/ should get a A- at least yeah i tried proxy /diskstation 192.168.1.4:5000 but it doesnt work. i get a page from the diskstation telling me that the page cannot be found. i guess this is some sort of security feature? i added the security headers but i only get a B-. Content security policy and public key pins are red. he was trying https:/mydomain/emby without a port before and it wasnt working. i can ask him to try again. i'll be there in 10 days but he's competent enough to add the details correctly. i think
