panamakevin 4 Posted June 27, 2017 Posted June 27, 2017 I recently purchased the membership and was trying to get Cinema Mode enabled... I can't seem to tell that it is doing anything. I have added the Trailers plugin and tested that it is pulling trailers, but it won't add them to the beginning of movies. I've tried changing the selections between movies in theaters and coming on bluray, and also tried clicking and unclicking many of the other options but still get these issues... I have read through several posts and followed the github directions but its still not working. Any suggestions or advise would be greatly appreciated! Let me know if logs would help... 1
Luke 42202 Posted June 27, 2017 Posted June 27, 2017 hi there @@panamakevin, yes a server log would be useful. you can learn how to attach one here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Also, what cinema mode settings have you configured? thanks !
panamakevin 4 Posted June 27, 2017 Author Posted June 27, 2017 Thanks for the quick reply Luke! I have attached my most recent log and a pic of my current cinema mode settings, though I have tried many variations, but haven't had any luck with pulling any trailers, regardless of what I click in the menu... Log (1).txt
ebr 16309 Posted June 28, 2017 Posted June 28, 2017 Hi. What app are you using for playback? Most of them also have options to enable or disable cinema mode. Edit - I see from your log that you are using the web app so you should be good there. If you disable those last two checkboxes you have enabled, does it play a trailer? Do your items have full metadata with genres etc.?
Solution panamakevin 4 Posted June 29, 2017 Author Solution Posted June 29, 2017 (edited) Not sure why, but its actually working now without any additional adjustments. Maybe it just needed a bit to kick in? EDIT: I forgot to answer your question on metadata. I do have full metadata for each film that should include genres... Edited June 30, 2017 by panamakevin 1
Luke 42202 Posted June 29, 2017 Posted June 29, 2017 Thanks for the feedback. I'll see if I can reproduce that.
