Marco2G 4 Posted June 26, 2017 Posted June 26, 2017 (edited) Hi there! I'm having an interesting issue. Streaming from my server seems to work perfectly fine. After clicking play on a non-downloaded item, it will start to play after a few tenths of a second. However, the stuff I previously downloaded just will not play. The loading indicator will appear and it'll stay like that for hours. Opening the local files directly with VLC works fine, though. My server should be up to date as far as I'm aware. I will attach the android log files. Thanks in advance 19b44b8d-e33f-4e3d-8f88-4ec16f991dcf.log 3575bcd4-f378-4770-811b-33587ea2e49a.log 91bf3725-d3c5-49a8-bd3b-a93fa1bc1e52.log a48e0396-bc9e-47b3-81c1-70b99c0b8d97.log edea0ec6-9acb-4969-b3d2-ab95665015c2.log Edited June 26, 2017 by Marco2G
Marco2G 4 Posted June 26, 2017 Author Posted June 26, 2017 Hmm it seems I was mistaken. At least one season that wouldn't play when downloaded also doesn't play when streamed. Perhaps this is a problem with decoding the file in the first place. I will try with other files.
Luke 42243 Posted June 27, 2017 Posted June 27, 2017 Hi @@Marco2G, it's a known issue in the current version. If you remove the download then it should stream just fine. thanks. 1
