carloshmm 1 Posted June 25, 2017 Posted June 25, 2017 I tried to play this video: magnet:?xt=urn:btih:ED1D8B5108B9911DCB6D3875A8D141BEA79D2FBF&dn=O.Abutre.2015.1080p.Dual-WOLVERDONFILMES.COM&tr=udp%3a%2f%2ftracker.openbittorrent.com%3a80&tr=udp%3a%2f%2ftracker.publicbt.com%3a80&tr=udp%3a%2f%2ftracker.istole.it%3a80%2fannounce&tr=udp%3a%2f%2ftracker.ccc.de%3a80&tr=udp%3a%2f%2fopen.demonii.com%3a1337 But as soon Emby server started the transcoding process I get this error message: Too many packets buffered for output stream 0:0. Conversion failed! and the video didn't start playing. Full logs in attachment (debug mode enabled). logs.zip
carloshmm 1 Posted June 25, 2017 Author Posted June 25, 2017 What Emby installation is this? docker? Installed on Linux from sources: https://github.com/MediaBrowser/Emby/releases/tag/3.2.20.0
Luke 42245 Posted June 25, 2017 Posted June 25, 2017 Did you follow the procedures on the download page of our website? https://emby.media/download.html None of the installation guides send you to github to download anything, that is why I'm asking. Thanks.
carloshmm 1 Posted June 25, 2017 Author Posted June 25, 2017 (edited) Did you follow the procedures on the download page of our website? https://emby.media/download.html None of the installation guides send you to github to download anything, that is why I'm asking. Thanks. I'm using Arch Linux and the binaries offered there are out of date: https://git.archlinux.org/svntogit/community.git/tree/trunk?h=packages/emby-server So I just edited the PKGBUILD file to point to the last version available and compiled all by myself. Nor the Arch Linux binaries or the last version that I compiled from source are working, both are getting the same error message. Edited June 25, 2017 by carloshmm
Luke 42245 Posted June 25, 2017 Posted June 25, 2017 Well the short of it is you may need a slightly older ffmpeg build https://trac.ffmpeg.org/ticket/6375 You may need to raise this with the maintainer of the arch linux package. In the near future we are planning on having an arch linux package officially provided by us, although we do not have it ready yet.
Happy2Play 9812 Posted June 25, 2017 Posted June 25, 2017 Don't believe we have any player that will play "video: magnet" .
carloshmm 1 Posted June 25, 2017 Author Posted June 25, 2017 Well the short of it is you may need a slightly older ffmpeg build https://trac.ffmpeg.org/ticket/6375 You may need to raise this with the maintainer of the arch linux package. In the near future we are planning on having an arch linux package officially provided by us, although we do not have it ready yet. Ok, I'm going to try this and reply here with the results. Don't believe we have any player that will play "video: magnet" . Well, the support team may need the video sample that caused the problem, that is it ;-)
