Solution Luke 42253 Posted December 5, 2017 Solution Posted December 5, 2017 Our Trakt plugin has been updated to 3.1.2. Due to Trakt API changes, you will need to install the update, and then re-authenticate using the trakt plugin configuration screen. In addition, there are improvements to the Trakt syncing process. Please let us know if this helps. Thanks ! 1
cublikefoot 3 Posted December 6, 2017 Author Posted December 6, 2017 Thank you! It now works when manually marking something as watched.
James 31 Posted December 7, 2017 Posted December 7, 2017 thank you so much. can't believe how much I actually use trakt and this plugin
