Angelblue05 4132 Posted June 29, 2017 Posted June 29, 2017 Ok, thanks. I think I have an idea how we can fix this in the future. I guess it must be holding too much in memory while processing data from your server. So I'll modify the process for it and we'll review it then. For now, you can workaround needing to do the initial import: https://github.com/MediaBrowser/plugin.video.emby/wiki/Create-and-restore-from-backup
CvH 14 Posted June 29, 2017 Author Posted June 29, 2017 I think I have an idea how we can fix this in the future.If you have something to test just ping me, I have several platforms to test 1
Angelblue05 4132 Posted June 29, 2017 Posted June 29, 2017 I will take you up on that offer. I just need some time, thanks Sent from my iPhone using Tapatalk 1
CvH 14 Posted June 29, 2017 Author Posted June 29, 2017 http://releases.libreelec.tv/LibreELEC-Virtual.x86_64-8.0.2.ova and import into VMWare (VMWare Player is enough) - VBox isn't supported. Pls note that after the import and before you start the VM the first time you have to resize the HDD at the VMWare options - or you end up with a 500mb HDD. With >=LE 8.2 (9.0 ...) the normal Generic image supports VM out of the box and the "special" VM image will be dropped (Milhouse Generic builds for example could be used if you like to test K18 - install 8.0 and then update to a Milhouse build, a ".nocompat" file at the update directory is required atm).
sualfred 677 Posted March 5, 2018 Posted March 5, 2018 ping @@Angelblue05 to keep this thread in mind CvH told me on Kodinerds.de that this issue still exists.
Angelblue05 4132 Posted March 5, 2018 Posted March 5, 2018 I thought it was settled that it was caused by the lack of memory, right? Sent from my iPhone using Tapatalk
sualfred 677 Posted March 5, 2018 Posted March 5, 2018 Yes. Mostly for larger databases on 1-2gb machines.
